CRX, I was noticing some odd things concerning the xhp70, 70.2, 50 and 50.2 Die.mm2. or die area.
For instance, the 70.2 is just 4 x xml2 (I think) so the total surface area would be like in your old chart 15.68 mm^2. Why does you new chart show a much larger area of 31.52 mm^2?
I keep meaning to come back to this to update it, I think I copied those numbers are from koef in this post. LES not die size probably.
“The total light emitting surface (LES) area of the XHP70.2 is 31.52 mm² (0.0489 sq in) in size. The four single dies are 7.88 mm² (0.0122 sq in) each.”
I believe the dome increases the apparent die size by about 50, not 100. Look at the examples I mentioned, there is no big increase at all, much less doubling.
Overall, you’re missing my point. The LES should not be on the chart. We want the actual die size like length times width. Perhaps another column can be made to show LES or the effects of the dome.
Die area in mm^2:
XP-E2 Torch: 0.85 (basically the same as the normal XP-E2)
XHP-50: ?
XHP-50.2: 4x 2.06
XHP-70: ?
XHP-70.2: 4x 5.581 / 4x 3.55 (de-domed XP-L2, entire glowing surface or just the blue die underneath)
Koef3 didn’t dedome all of these LEDs. He only states the values with dome in some of his threads.
Osram oslon red SSL80 (the “SSL80” is part of the name, not binning info, they make other types of 3.1mmx3.1mm red emitters too so its important to include it in the name)
Package size 3.1x3.1mm
Diag. Max 4.38mm
Total height 2.35mm
Substrate 0.68mm
Dome Ø 2.15mm
If that’s not enough info for you to bother adding it to the chart I understand.
