Oh I see, that makes sense.
I’ll see if I can find something used, would rather pay $500 for a class A luxmeter than $200 for a tasi which I might want to replace later on.
I wonder why the high CRI 6500k led was so much worse than the 70 cri 6500k on the 1330…
I find it pretty complicated to relate the reading error of luxmeters to the combination of the led output spectrum and the deviation of the sensitivity curve (it is interpreting 3 curves at the same time, of which the led spectrum has multiple peaks :confounded: ). In this case I think the extra reading error of the high CRI 6500K led is caused by the high red content, the LX13130B not just over-reads the blues, it also reads everything above 620nm pretty high.
I have the LX1330B as well, I find it reads low, by alot. Comparing various flashlights and known Lux values, my particular meter reads at least 15% low.
I’d like to mention, if anyone is building a similar flashlight maybe consider using this reflector I found on ebay:
It’s made of glass and will not flex like the electroformed reflectors do, as well as a 4” focal length instead of 3”, which will make focusing easier.
No info on the surface precision or reflectivity %, but for $170 it’s a great price for this type of optic.
Only difficult part will be making a mount for it which centers properly while protecting it from damage.
There are datasheets and there is experience. The LED in my light is the best of 9. The worst one was 30% dimmer at Max. They were all soldered in the same way, but reflowing by hand is never a perfect process. It might simply be that small differences in the solder process create such a large variance.
Unless you measure the luminance of your specific sample, you will never know! It’s the most logical reason for your performance “problems” (in addition to the focussing aspect).
Cool. You could make a case for the mirror and embed it in a stiff foam, i.e PUR foam. Then either hang the complete case in an adjustment system, or fix the case and do all adjustments at the led.
Huh, and they were all bought at the same time? Do you know if you possibly crossed a stock multiple of 2000 when buying them?
I need to buy some more flat blacks to bin them, maybe some more mcpcbs too.
Yeah, moving the LED instead of the reflector would probably be best in that case.
I’m really tempted to buy one for $170, even though I don’t have any light to use it for…
Great find! Looks/is pretty much identical to the glass reflectors in marine searchlights, but orginal reflectors cost atleast twice as much.
Btw, congrats on the new lux reading :+1:
Someone on TLF is making a huge project with 3 of the 24” ones, but haven’t seen any updates in a while.
I have no idea how accurate their surface is, or what the reflectivity of the polished aluminum is.
It seems like just a stamped piece of metal, which would be far less precise than electroformed optics.
The material is not good,
Thats why we call it “Salatschüssel”_—-salad bowl.
No Update cause of doesnt work well with Led recoil.
It is what you say- stamped piece of metal,
We will try 280 mm glas reflector from cinema with CFT 90 @ 30A. :innocent:
It need just some time…
Yes, the first six were bought at the same time and thete was almost 30% variance. When the light was repaired three new ones were tested and one of the old ones was tested together with the new ones. One of the three was better than all of the ones before that.
Yeah, too bad these weren’t available when I was designing the Syniosbeam They do look very good quality.
Thanks
Ok thanks for the update, that’s what I thought.
Unfortunate that the edmund optics reflectors didn’t work out.
If you want to go big (since you’re not making a portable flashlight) the same seller on ebay has 476mm parabolic reflectors too, you don’t need to limit yourself to 280mm
You should get close to 30Mcd with this setup!
PS- I would recommend that you use an NH-D15 heatsink instead of your current heatsink for better cooling performance, you should be able to drive the LED at 40-50 amps and get even more power.
Thanks for letting us know.
I have one question about it. I contacted them asking how deep it is and they replied very quickly saying its 1 7/8 inch deep. If it has a 4 inch focus length, does that mean that the led would have to be mounted almost 2 inches in front of the rim rather then below it like your one is? and there by letting some light escape?
Yes there will be some light escaping, very little though.
You can use this calculator to estimate the performance and lumen collection and all that stuff.
The reflector I have with 3” focal length has the outer edge about .5” from the LED plane, so it collects a more extreme angle of light (which is what makes it very difficult to focus)
This 4” FL reflector will collect 85% of light instead of 96% like mine, which is a very small difference, and I think it’s worth it for the improvement in focusing ease.
