Group Buy: Wuben TO10R and TO46R (real 90+CRI triple XP-G3) - CLOSED!!
Yes you can, it has a low voltage warning at 2.8v. It’s designed to use protected cells so expect battery rattle. A bit of insulation tape around the cell can solve that. If you drop the light while it’s on it might switch off due the lack of spring compression when using the shorter unprotected cells. I did a drop test on a carpet. So I’m sticking to protected cells in this light.
ok.but using the xpl or nichias predict to use a different driver…for maximum output…iam right?
Using XPLs, you will get more output at the expense of runtime and less constant brightness.
Using Nichia 219Cs 4000k 90CRI+, you will get slightly less brightness in exchange for much longer regulated runtime and even better color temperature.
no need to change the driver??
No. You are swapping 3V LEDs for 3V LEDs. No problem there.
hm…i wonder,how much lumens can we reach with the lets say nichia upgrade…what do you think?
About the same really, but brightness will stay more constant over the runtime of the light.
Not really. The output is fully regulated other than a timed stepdown at about 2 minutes on turbo and high (high and medium on the TO10R).
What kind of driver does it use?
I’m interested.
This is a fantastic light. I am really enjoying mine. The only niggle I have is that the clip is not deep carry. Other than that rectifiable qualm, I really like everything else about the light. Buy one, you will not regret it.
Regards,
Frank A.
Frank, if you have a extra A6 pocket clip, it works nicely.
Todd-
Thanks for the heads-up. I do not have an A6 clip. Any idea where I can buy just the clip? Thanks!
Frank
Astrolux S1/BLF A6 Flashlight Stainless Steel Titanize Body Clip Flashlight Accessories
https://banggood.app.link/29j9cIKvCN
S2+ clip works well on the second cut out on the tail cap as well. Gives you two choices in clips.
Thanks Kevin & Todd! I ordered a couple of the clips from Bangood.
Frank
Got my review of the TO10R and TO46R up here: Wuben TO46R & TO10R review (3x XP-G3, 18650/16340)
Also did some experiments with emitters, optics and filters. Spoiler: you can get the XP-G3 to look good with a frosted Carclo and a minus green filter but at the cost of output. LH351D is still better.
Update 2018-06-11 22:00 UTC: Wuben just set a hard deadline for this GB: Everyone must make their orders / finish their payments in the following 24h. After that, all unclaimed lights will be shipped to me. (No exceptions, no payments after that deadline!)
Ok, It’s been 6 days since I asked and got a kinda vague response…so I’ll try again.
Have ANY lights from the GB shipped yet? When can I expect mine to ship?
The update above really doesn’t address the question(s) and the smell of smoke from the recent Haikelight forest fires doesnt make patience as unconditional as it used to be.
Tracking doesn’t work for shit
Received an email w/ tracking number from Jason of Wuben on June 1st.
