I’m not a good judge of reflector finish, but if you want to try and center the reflector you would need to loosen the upper head from the light engine. The threaded section right above the switch. When you loosen it there you can wiggle the reflector some to get it centered, then tighten it back up. If you completely unthreaded and separate the two parts you need to make sure to put the black centering ring on the emitter first and then thread the head down onto it.
But I hope that Lumintop is working on a next version of the centering piece, it is not that hard to make one that actually does center the led, and if there is one flashlight that demands a well-centered led it is the GT. And trial and error DIY wiggling a reflector is not what you hope for in a high performance flashlight (I had to do that too often already in my budget cheapies).
I presume I should polish the reflector myself too?
I know how to center an emitter, this is irrelevant though. This should have been done at Lumintop not in the buyers garage.
95% of the splendor of this flashlight is a reflector and just this most important thing is screw up.
Thank’s djozz
I too have cheaper flashlights with better quality of reflector.
It beats me how Lumintop can’t get it centered just right. The design of the black centering ring is pretty much fool proof. Maybe the screws are not the best thing to center it on. Maybe their tolerances are not tight enough. Maybe they switched to screws with a smaller head so now the centering ring can wiggle.
I think the reason they switched to using the screws to center it was because the emitter corner would sometimes gouge the black plastic and create a black plastic shaving which could then fall on top of the emitter and smoke up the reflector.
All they really need to do is cut the center hole with a taper on the bottom so it self centers. Done.
Ok, I don’t have time to address each post but first off lets all take a step back. The GB is over now, lets not start up drama after the fact.
I will freely admit that mistakes were made in the GB, particularly early on.
Lumintop’s choice in how to ship out and handle orders was not what anyone on here wanted but trying to change it was just not easy to do and most of it did make some level of sense from a business standpoint. It was a case of pick our battles.
Retrospect is 20/20. Would I have done things differently given the chance? Yep. Heck at many points getting involved at all seemed like my biggest mistake. lol
I like to think we corrected most of the issues by the last 2 batches, they went off very smoothly IMHO. These were also how the entire GB was supposed to go. The reflector delays threw a massive curve ball in the whole process no one saw coming.
I apologize to all those that got lost in the cracks throughout this GB. That is something I never wanted to happen.
When this was started the entire GB was only supposed to take ~1 month start to finish. So in that time frame it was understandable to take care of the big issues before dealing with the small ones.
Had we known it would be a 6 month long ordeal, things would of been handled very differently.
The issue with the centering rings was that the first style would melt after extended use, which I did see evidence of in my prototype light. This could smoke up the reflector and cause lots of issues.
I have told them to more to a white centering ring a few times but never really got an answer about it.
Smaller flashlights have centering rings that fit snugly around the led and are centered by the led itself. I can understand that with a reflector this heavy you don’t want that in fear of shearing off the led when the flashlight is bumped against something. Their solution is not bad: position the two screwholes for the ledboard very precisely and use the screw heads for precision-positioning of the centerpiece. But those holes must be indeed positioned precise, the screws must have precise heads (preferrably not round but with a straight edge), and the screws must be screwed in with some care so that they go in straight without cross-threading. One or the other was off in part of the GT’s.
Thanks for the pictures smokuxx1987. :+1:
As for your other comment… your barking up the wrong tree my friend. BUT I will be more than happy to oblige you for that ’mistake’.
Good informative video Jason, I noticed that you haven’t cleaned the soldering flux off the contact wires, you might want to do that before running your light at full power for long periods of time to prevent it from smoking the reflector.
This is how mine was before I cleaned it with alcohol and a Q-tip being careful not to leave any strands of cotton afterwards.
I don’t have any liquid under my centering ring. Are you talking about the flux residue around the solder points? That is dried up and hard. It should not cause any problems.
Excellent info & pics AlexGT!! I remember when you first posted this. Your pics convinced me to clean all of mine before heating them up real good. None of mine were as bad as yours appeared to be… but better safe than sorry.
Thank you!!! :+1: .
Jason…. Look closely at AlexGT’s pictures. Look at all the liquid crap that was under & on the bottom of his black spacer. Look at what is on his fingertips also.
I am pretty sure that mainly is what he is referring to.
He said I need to clean my light, but I never had excess flux under my centering ring. Nor is there any visable in my video. So I’m just confused why he would tell me that.
