the newest craziness 9x XM-L U2
70 posts / 0 new
viffer750
Last seen: 5 years 11 months ago
http://item.taobao.com/item.htm?scm=1007.105.0.0&id=14230331591&ad_id=&am_id=&cm_id=&pm_id=
What the hell?  Smile
I'm curious how ugly is the beam pattern, but no doubt, it's a monster.
1
unique engrish language... Smile
Edited by: viffer750 on 02/26/2012 - 16:17
Chicago X
Chicago X's picture
Last seen: 9 years 7 months ago
Interesting method of LED placement.
I want that host badly.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
CheapThrills
CheapThrills's picture
Last seen: 3 weeks 4 days ago
This is going to get floody...
Don
Don's picture
Last seen: 2 years 3 months ago
Wonder how much smoke it will produce? And how long it takes to explode. Sounds more like some sort of grenade than a light.
27A for 9XM-L in parallel. What sort of cell can handle that? Not anything that'll fit in the 280mm length. Google Translate didn't help much here. At most it is long enough for 3x18650 in series. Which means 8A each from them! Better use good IMR's.
27V at 3A in series. Which would mean 7-8x18650.
If these are driven hard which I doubt this is an 80W device!
And if I read it right that's a US$450 device. Probably double that from the usual free shipping suspects.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
yavi
Last seen: 1 year 11 months ago
What a monster!!
I think I would go for HID instead for such power consumption, I do not feel those XM-L will last too much being so close to each other.
viffer750
what I see:
4-6-9 * 18650锂离子电池或4-6-9 * 17650锂离子电池或8-12-18 * CR123A或2-3*C(26650)锂离子电池或2-3*D(32650)锂离子电池,使用加长筒(另购)时可达3D锂或9*18650等电池。
with google translator:
Or 4-6-9  * 18650 lithium-ion battery or 4-6-9* 17650 lithium-ion battery or 8-12-18 * CR123A or 2-3 * C (26 650) Lithium-ion batteries or 2-3 * D (32650)lithium-ion battery, plus long-barreled (optional) up to a 3D lithium or 9 * 18650 battery.
yavi
I am not sure, but the same seller has this pill, with 4*SST-90 on a CSM360 module, I am not sure it is compatible with the same host, but it should also generate quite a lot of heat for winter.
http://item.taobao.com/item.htm?scm=1007.77.0.0&id=10925032140&ad_id=&am...
Chicago X
Chicago X's picture
Don wrote:
.... At most it is long enough for 3x18650 in series. Which means 8A each from them! Better use good IMR's...
While that current draw would be extreme for typical 18650s, for a 4000mAh 26650, it's only 2C - well within most published specs.
For comparison, that's similar to the load placed on a typical 14500 by a well-driven XP-G, or a triple XM-L run at 3A with 2-cells.
At this rate, the XM-L is going to become this generation's 5mm LED - 109 XM-L 'showerhead,' anyone?
Chicago X
Chicago X's picture
yavi wrote:
I am not sure, but the same seller has this pill, with 4*SST-90 on a CSM360 module, I am not sure it is compatible with the same host, but it should also generate quite a lot of heat for winter. http://item.taobao.com/item.htm?scm=1007.77.0.0&id=10925032140&ad_id=&am...
SurprisedSurprisedSurprisedSurprisedSurprisedSurprisedSurprisedSurprisedSurprisedSurprisedSurprisedSurprisedSurprisedSurprisedSurprisedSurprisedSurprisedSurprised
That's a $200+ 'pill.'
Foy
Foy's picture
Last seen: 7 years 9 months ago
80 watts . . . 9 x XM-L in parallel . . . yowser!  Also, that 4 x SST-90 pill looks awesome.
I must say; judging from this, these guys seem like true flashaholics . . . . with no fear of the after-life.
whohasthebrightestpipebombFoy
No referral links and nothing embedded . . . ever.
                      &nbsp
Don
Don's picture
My thoughts exactly!
You just said it better.
newbie74
The 9 leds will operate at 12v.
Get the two 9*U2 pill, solder it to a big copper heat-sink and you may have a headlight....
CheapThrills
Cracked me up
dthrckt
dthrckt's picture
yes, please
ok, I can't afford it - 109 xb-d though?
T.H.Cone
T.H.Cone's picture
Last seen: 2 years 1 week ago
Will it melt the Nerf gun it is going to get mounted to?  I need to know because my kids like to accessorize like their big boy heros.
fidem, prae caeteris omnibus praeter honestatem
Don't be confused, my Username has been changed from "Cone" to "T.H.Cone".  I'm still the same clown.
dorpmuller
dorpmuller's picture
Last seen: 3 weeks 8 hours ago
Flashlight nirvana. Wish Taobao had an English setup.
"I am the flashlight king! I can light anything!"
WastedNihilist
WastedNihilist's picture
Last seen: 1 month 1 week ago
Anyone else notice each picture appears to be a different light? 1 with 5 leds and 1 with 7 leds and 1 with a smooth reflector. Seems almost light bad photoshopping or something.
Chicago X
Chicago X's picture
There are three different lights for sale, in 5-, 7-, and 9-XM-L configuration.
df2dot
Last seen: 2 years 9 months ago
they are representing the different models in their pics - frankly a 3 or 4 banger would work for me
  • 灰色/XML-T6*5
  • 灰色/XML-T6*7
  • 灰色/XML-T6*9
  • 灰色/XML-U2*5
  • 灰色/XML-U2*7
  • 灰色/XML-U2*9
PilotPTK
Last seen: 9 years 1 week ago
9 XM-L's in, what, a square inch?  Yeah.  Good luck with that.  Unless they found some super-metal to use as the pill, it will be so freakin hot in about 13 seconds that the XM-Ls will burst into flames.  In my light with 24 XM-L's, I had to add 4 pounds of aluminum with more than 450 sq. inches of surface area to even think about controlling the heat produced - and they're far more spaced out.  Back of the napkin calculations suggest that 80 or 90 watts into 2 cubic inches of copper would yield a steady state temperature of about 300C - some heat is going to be dissipated by convection through the host, but I would still suspect 200+ C.  I know I don't want that thing in my hand.
When LED's are 80% efficient rather than 10%, That will make a kick-ass-host.  For now, it's just not practical.
PPtk
I am currently extremely busy with work. Please do not expect a response from me quickly. I will be dropping in as time permits, but the amount of time I can dedicate to responding to topics and PMs is very limited.
WastedNihilist
Oops. I need to work on my chinese.
dthrckt
dthrckt's picture
is the beamshot of the sr92 with it on low or something?!
2100
It's from this company   : http://feilong.us/
2100
Oh....they said for the 9 XM-L model can use 3 x D sized 32650.
From KD's smaller 32600 5000mAh, mitro did 4500mAh @ 5A (I measured 5200mAh @ 1A). The KK 26650 did 10A nicely. So I think battery requirement would be taxed but it's not impossible.  However it is non-protected, definitely not for the novices.
The light is the 2D80 model, 80mm++ head and 3D long.  So something like TK70 just smaller by 20mm. 1kg mass, 200g more than TK70.
9-XML must use 3x 32650 tube.  Not sure if it can do 3S3P 18650.
For the 7-XML and 5-XML models it can use  2D tube, or 2S3P 18650.
It's 80mm reflector with somewhat spaced XM-Ls.  Hence it is still something like a floodlight, or think of it as slightly worse than 9 XM-Ls with individual reflectors squeezed inside.  From the beamshots, it still throws less than the SR92, and the SR92 has 45k cd.   It's damn bright (lumens) though.
PS. As always, never take the output specs at face value, someone tested the CSM-360 and was disappointed.
It's taxed real bad, but not that "mission impossible".
The problem with such a design is that it is not mounted on 14/16mm MCPCB like the DRY, TR-J12, usual triple XM-L suspects.  Take for eg the DRY, ignore the output but basically that is a 40W or 40W plus light depending on the amps that the cells can push.  It's mounted on a light weight host but the LEDs are on 14mm.
Even with direct emitter bonding, it's too close. Overall efficiency would be like the DRY once past a certain point (eg it's 3A for the triple XM-Ls and it slides down significantly).  Even if the driver can take it, say instead of 8000 lumens theorectical, it probably might be 6500 lumens.  With that mounting the efficiency takes a heat as it's really different from individual 14mm MCPCB or slightly cut 16mm MCPCBs.
6000-6500 emitter lumens from 9 XM-Ls sounds doable in such a package - but then again it's too expensive.  2 x TR-J12 gives nearly 5000 lumens OTF and costs about usd160 shipped.
2100
Note : 2 x TR-J12 has a total of 10 XM-Ls; 2 lights of 65mm head diameter each (so you can calculate total area).  It would have 48k cd, so it's same throw as the SR92.  this feilong has less throw than SR92.  I think the this 2D80 feilong light is not optimised in one way or another....
Manual Man
PPtk
Super metal? Na... they use a super liquid, helium ll to be precise (I wish).
"The thermal conductivity of helium II is greater than that of any other known substance, a million times that of helium I and several hundred times that of copper" (Wikipedia) http://www.youtube.com/watch?v=2Z6UJbwxBZI
Nice... where can I get some?
PilotPTK
One small problem with this theory.. Just touching a torch containing He-II would freeze your hand pretty quickly. If memory serves, Helium is only liquid at like 2K (2 Degrees C above absolute zero).  There also isn't a flashlight manufacturer on the planet that could design seals and threads capable of keeping liquid helium from leaking out.
Smile
Manual Man
Not to mention the heat would have nowhere to go :glasses:, darn it. Scientist need to hurry up and invent magic. (actually we do have it, but it is virtual Silly )
yavi
I don't find it to be a fair comparisson 2100, if you continue that way, you could say, 10 X UF-2100 will give you the same for 100USD.
This is a single light, there is no way to compare to two sepparate lights in my opinion.
2100
Haha...you are right.  Someone did tell me to tape 3 x UF-2100s together to get a triple XM-L.  The UF-2100 is $14.50 cheapest from what i come across though, i like that thing with 4.7kHz PWM!
But this really is a floodlight. The truth is this....  Something is preventing it to be so far below SR92's 45k cd, coz even by sheer power as a floodlight, it should be able to do above 45k cd. Heck I got nearly 30k cd from the 54mm diameter Sky Ray 3800, DDed of course.
 I guess the spacing is a bit worse than typical budgetlights.  Take the above mentioned TR-J12 for example, it's 44k cd for 9 XM-Ls.  Area is 30cm^2 for TR-J12. Minusing off those area which are unused and it could be say 25cm^2?  It's actually about 460 lumens for each XM-L, it's not a flashlight which has its emitter gunned like there is no tomorrow. Eg, DRY.
Feilong is 8cm, or 50cm^2. And it has a whole single reflector. But it is noticeably less throwy than 45k cd.
What I can think of is :
(1) Noticeably less lumens per emitter than even a TR-J12, low drive levels. Could be due to (a) driver unable to support those power, though they are "rated" - doesn't mean that they need to do that in reality  (b) battery cannot supply such juice. But not likely as you need only 10 amps for each 32650.  I have good experience with the 26650 and 32600, the 32600 happily does 4.5A and does not even get hot much and lose much capacity.
(1a) what I am afraid is that due to point 1, the lumens output is there also. That is logical.
(2) Heat is affecting the output even at lowered drive levels due to the emitters designed in a cluster.
I actually have the XTAR S1 which is effectively a 85mm head diameter light and 3P battery config, and i have examined the driver space.  Not too much space there, but of course much better than the usual multi-XML lights that i have (quite a lot there). The TK70 is a 105mm class multi-XML light that accepts the same 32mm diameter cells, slightly better.  The thing is that heat output of the lights affects them driver electronics. You can drive them hard of course, but they won't last past a few minutes.  That said, the DRY 3 x XM-L is a different breed, it's a light for the lumen junkies, truly unlimited/unrestricted stuff.
2100
I still can't find that CSM-360 by feilong tested by a Russian guy....they were saying there were some drive problems, just not driven hard enough and it's not that bright at all from the measurements.
Don't get me wrong, it's an interesting concept.  The modders have done dual emitter versions on a single reflector, so it's not new. MC-E is a quad, the very little known CSM-360 is a quad as well.  But 5/7/9 emitters is new and definitely "hauls ass". But perhaps it would be better if the neck is made bigger with more fins, and they use at least a 100mm reflector preferably 150mm, and make it as special edition.
Folks can get like 300k cd with 75mm with HIDs.
