Thank you klrman! :+1:
Is the UM25[C] just are more precise version of the UM24[C]? I just saw that RuiDeng has released their UM34[C] which is the successor of the UM24[C].
I read that the UM34C is lacking a PC app for the bluetooth model whereas the UM25C is accessible via PC and Android Apps. I’ve been considering the UM34C but I’d prefer the option of a PC app.
Looking at the specs, the UM34C is an upgrade over the UM24C, though not necessarily of the UM25C.
The UM25C has more precision (+1 more digit), and also works with Windows app.
The UM34C has USB 3.0 support though (which the UM24/25 do not — they’ll work as USB 2.0 only), similar precision as the UM24C, but no Windows app (I wonder if they may develop a Windows app in the future to support the UM34C though); display interface looks more like the UM25C (other than the 1-digit less precision)
I also notice there are 3rd-party USB meter being released right now that look like the UM24, but has some differences (notably this “A3 USB meter” has type-C port), but the display screens look almost exactly like the UM24.
If all goes well, I'm getting that A3 in for a video...
Who has the best price on UM25C currently? Any coupons out there?
Thanks!
$20.88 at banggood right now for the um25c. I couldn't find a coupon so went with their sale price when I ordered. Mine was $5 cheaper as I did not get the bluetooth version.
Official RuiDeng AliExpress store:
The price there is $21.50, but ordering 2pcs drops it to $20.86/pc.
No news yet on that A3, but I am getting the UM25C and UM34C from RuiDeng themselves :)
Hi guys, I just got the UM25 without bluetooth and am a bit confused at what I’m seeing. (This is my first one of these devices)
It’s using 5V from the computer to the device plugged in, lets say a NiMH/Li-ion charger from O-Light with magnetic leads and auto-sensing polarity. With an Eneloop in the circuit the UM25 is showing 4.969V and 0.1954A. This is showing me how much power is being pulled from the computer’s USB port, but not how much the charger is using. I used my clamp meter on the negative lead and it shows 0.51A going into the cell.
So how do I figure out the conversion? Or is it not about that, merely about what the charger is pulling not what it’s putting out? But of course it’s advertised to be able to check the accuracy of your phone battery, but if it’s giving a reading of the charger current you really don’t know what the battery itself is doing, do you?
Sorry, random pic off the net… not my device plugged in.
Also, last night I was using it with my battery bank, this is a 12,000mAh bank that was down to the 25% indicator, but it charged up showing a bit less than 2000mAh used through the tester, I’m assuming this was because of the 5V use at the computer USB port, so what do these numbers do for me exactly?
It’s a USB meter. It has no way of knowing anything outside of that.
Hi guys, I just got the UM25 without bluetooth and am a bit confused at what I’m seeing. (This is my first one of these devices) It’s using 5V from the computer to the device plugged in, lets say a NiMH/Li-ion charger from O-Light with magnetic leads and auto-sensing polarity. With an Eneloop in the circuit the UM25 is showing 4.969V and 0.1954A. This is showing me how much power is being pulled from the computer’s USB port, but not how much the charger is using. I used my clamp meter on the negative lead and it shows 0.51A going into the cell. So how do I figure out the conversion? Or is it not about that, merely about what the charger is pulling not what it’s putting out? But of course it’s advertised to be able to check the accuracy of your phone battery, but if it’s giving a reading of the charger current you really don’t know what the battery itself is doing, do you? !{width:40%}https://i.ytimg.com/vi/gP89sSzcoo8/maxresdefault.jpg!:https://i.ytimg.com/vi/gP89sSzcoo8/maxresdefault.jpg Sorry, random pic off the net… not my device plugged in. Also, last night I was using it with my battery bank, this is a 12,000mAh bank that was down to the 25% indicator, but it charged up showing a bit less than 2000mAh used through the tester, I’m assuming this was because of the 5V use at the computer USB port, so what do these numbers do for me exactly?
I don't think the numbers add up, maybe you have a faulty UM25. How can the meter show 0.1954A and the clamp meter show 0.51A? My UM25C shows what the charger is using. If my flashlight has a 2A fast charger built in, the meter is displaying 2A or 2.1A until the saturation phase near the end charge cycle slows down and the meter displays that accurately too.
But the USB port is outputting 5V, where the cells charge at 4.2V, so there is a conversion factor for what the USB is using as compared to what the charger is putting into the cell, with some losses as no charger is 100% efficient, right?
What is the configuration?
5v USB port < USB meter < power bank
The power bank was 25% full based on its indicator.
Was the USB meter’s capacity reset to Zero when you plugged it in (capacity reading needs to be reset to zero first if measuring capacity)?
Assuming the USB meter’s capacity display was reset to zero, and the capacity charged reads 2000mAh, and the powerbank became full (display reads 100%), right?
Then that means 75% capacity is 2000mAh, so total capacity of the powerbank would calculate to something like 2667mAh.
However, my guess is the capacity readout (25%) of the powerbank is a “guess” [not that accurate] based on the voltage of the lithium-ion battery inside the powerbank, and not the actual capacity. Another thing is the power bank may have degraded in capacity (if this is not a “new” powerbank).
I recall testing a 10000mAh powerbank when it was relatively new (I didn’t have a USB meter yet when it was brand-new), but when I got that powerbank it had several cycles of usage, and I measured something like 8000+ mAh capacity. But right now (after 2 or so years), when I do another capacity test (it now takes a very longer time to “fill up” the last capacity, and it’s just something like 3000+ mAh capacity (from empty, charge to full, measuring capacity with the USB meter in between). Seems like a big degradation…
Yup, USB 5v vs lithium-ion nominally 3.7v so there would also be an efficiency factored in the equation…
I think it's different for Voltage. The USB port is always putting out 5V, but until a device is plugged in, it should display 0A until something is pulling current from it. That's how mine works, it always displays 0A until I connect something to it, but always displays 5V.
So the only thing that really gives any indication to the health of my cell phone battery is the mA put in, would this be fair to assume? (It lists mAh for some reason, which is capacity not active voltage if I understand it right)
Ok, so here is a pic I just took with the meter plugged into the 2A output of my USB3.0 hub, feeding a 10,000mAh Bank through a type C Kevlar braided cable…. this is a MI power bank rated at 5.0V 2A charge rate with the Type C inlet.
The display is upside down, sorry.
here is the full eng manual in pdf
The first link I posted in the OP is not displaying the full manual
I never checked mAh, but I think the meter displays it but I need to try it out myself to make sure
It’s using 5V from the computer to the device plugged in, lets say a NiMH/Li-ion charger from O-Light with magnetic leads and auto-sensing polarity. With an Eneloop in the circuit the UM25 is showing 4.969V and 0.1954A. This is showing me how much power is being pulled from the computer’s USB port, but not how much the charger is using. I used my clamp meter on the negative lead and it shows 0.51A going into the cell.So how do I figure out the conversion? Or is it not about that, merely about what the charger is pulling not what it's putting out? …
The figures match well, the USB meter sensed power in is Pin = Vin × Iin = 4.969A × 0.1954A = 0.9709426W. Power going into the cell is Pcell = Vcell × Icell, you did not measured cell rail voltage but anyway I am going to presume ≈1.4V, thus Pcell = 1.4V × 0.51V = 0.714W. This would be about 73.54% overall efficiency, not bad for a small low voltage device.
… But of course it’s advertised to be able to check the accuracy of your phone battery, but if it’s giving a reading of the charger current you really don’t know what the battery itself is doing, do you?
Bollocks. Your phone/tablet/laptop battery is totally under the control of its battery management circuitry. Get a proper application for the task. In Android, I recommend 3C Battery Monitor Widget.
New to smart phones as well, recently got the Apple i8. The charger that came with it sucked, I got the Apple 12W charger that supposedly charges at 5V/2.4A then I heard about the bigger chargers working on this new phone so I got a 29W that says it charges at 14.5V/2.0A (this i8 has the wireless charging capability, it’s supposed to be compatible and indeed does charge considerably faster with this 29W charger)
I have the UM25C for a few month. Nice device and paired with a 1A load good for checking USB cable resistance (good to show people why their 2 or 3m long ultra light and thin cables double or tripple their charging time). Overall a usefull little tool. And with the option to stop charging when the current goes below a threshold you can preset, is also nice.
Only thing i do not like is, that you can not change the divisions in the Current-Voltage Graph (app). If you have something that pulls 1A the current and voltage lines are ontop of each other.
