ill try later on when it arrives. anyway when upgrading . the instruction says check the “reset after flashing” on the program. does it resets calibration? and if i didnt check the “reset after flashing”, does it keep the calibration?? i cant calibrate it since i dont have accurate meters / source etc
In my case, the voltage readings of my ZY1276 didn’t seem to change (or if it did, it was too small that I hadn’t noticed it) before and after I upgraded its firmware.
Guys I have great news. So my ZY1276 just came in the mail. After trying it. I was so confused of the firmware version. Its already on 3.36D . And it appears that I have the new ZY1276P version (I know cuz when it shows the model number when you holding button bfore going to configuration mode) okay. So basically. I should be able to check emarker without PD adapter. No documentation yet. So idk. I’m waiting for my type c cables. Also. I’ve found a closed beta firmware . 3.36E (newer than stable) it removed some Chinese text. And vooc check . For beta testing QC to PD 2!! (He said the memory isn’t enough for new features so he needs to remove some to get some) . Haven’t tried it yet tho. He said something too about not using it with emarked type c cable. Anyway here’s the fw if you wanna test it. ZY1276 only!! I’ve flashed it successfully.
You’re right, i meant the voltage setting in the STM32 programmer software.
I do have the pogo pins, but can’t connect the ZY1273 to flash the firmware 3.1 on it.
but YZX meter did not have ,
For UM34C, it support USB 3.0 and Quick charge recognition mode:QC2.0、QC3.0、APPLE 2.4A/2.1A/ 1A/0.5A、Android DCP、SAMSUNG, support support OPPO phone VOOC, OnePlus DASH
Though UM34C and UM25C have Type-c port , but there is not trigger, only support type-c charge, not recognition
although for data or some function, it is not better than YZX meter, but for the price , it is already best …
for USB load, there are many choice , LD25/LD35
If someone need more cheaper meter, but colorful display, there is also choice AT34
