I’m in. I last used DC-Fix on a Sofirn SP31.
Im in, Thanks for GAW, would try to smooth out my 2AA Maglite
Im in, I have a few I would like to try it on…
I‘m in, too. I would like to use it on my Amutorch AM30.
I’m in. I want to try making a removable diffuser for my throwers with this sheet.
I’m in. I would use it on a TG06S to smooth out the hotspot, and try it on a fixed aspheric lens light that has visible rings.
I’m in
Thanks!
I am in.
VG10S, cheap C8 style with whack green ring LED and maybe a couple of others.
I am in. Used it on a Brinyte PD03A to smooth out the hot spot.
I am in.
Thanks, I’m in.
If I win, Zanflare F1 will be the 1st target.
I am in.
I would like to do Zanflare F1 Or Utorch 02
I’m in and still looking to smooth out some old Maglites.
I’m in.
I’d use it on a generic headlamp I got a few weeks ago. Headlamps with smooth reflectors… ugh! Definitely not good for close up. Needs diffuser.
I’m in. Would use to smothen beam of bicycle light like MJ-808. Thanks.
True Random Number Generator
Min:
1
Max:
26
Generate
Result:
3
Matchoo
post #3
It’s up to you to pick a winner !!!
Wow! I was tempted to pick myself but decided to spread the fun around some more. Using a random number generator, post #7 was chosen as the winner. Congratulations Calaveras and thank you Boaz.
Lucky number seven! Thanks for doing this. I will PM the OP
I am in. Thanks.
