I was told by Banggood there is a new discount code for this light. Use the discount code 3a103e for 37% off the regular price.
BTW, this is my new “thrower” I carry when cycling this year, on a lanyard around my neck for easy access. It makes a great combo with the floody BLF A6 I use for my mounted cycling light.
Turn the light on, then rapidly half-press the switch a bunch of times (10 or 15 should do). It will then do a series of blinks. After the second set of blinks, turn the light off. That will toggle memory mode on or off.
You might have to try it once or twice to get the hang of it. If you turn it off after the first set of blinks, you’ll toggle 4 mode or 7 mode. If you make a mistake, just do the same thing to toggle it back the way you had it.
thanks. i just did it twice, had to half-press more than that actually and i did wait for the 2nd set of blinks but even after switching it off it still doesn’t have memory mode activated. Are there any Astrolux C8’s that function on a different driver perhaps?
Are the parts of the Convoy C8 and this Astrolux are interchangeble, do they lego?
I am interested in battery-tube, Tailcap, Bezel and perhaps driver-retainer-ring, if they can be exchanged (if needed).
The stainless steal Bezel would look nice on this C8 too, if possible.
I did a quick test on a couple of the parts, and they do appear to lego just fine, at least with the clear aluminum version of the Convoy.
I’m guessing you just want to put the driver of the Astrolux inside the body of a Convoy? Should work, though there may be a cheaper way of doing it by just ordering the driver.
My Astrolux C8 just arrived. On turbo mode it is insaine bright. On the 6-th level has same brightnes as Convoy C8 XPL HI on 100%.I think that on the market this is best thrower you can buy in C8 format. May be only Sofirn has similar model but it has cool tint.
Yes, FET drivers (Astrolux) definitely win out over linear drivers (Convoy), especially on full batteries. This assumes you want full output, which IMO is the only way to use a thrower!
Only a boost driver can do better than a FET driver, but there doesn’t appear to be any budget lithium-ion lights that use boost drivers.
I have a question.
How BLF X5/X6 driver work with step down on turbo?
When temperature reach one level it goes on lower mode or it reduce output level smoothly in small steps?
Thanks for posting this and your good explanation. I was thinking that I had to wait until a pair of blinks had completed before turning off. I could not get the memory mode or 4-mode to work. It was remaining in 7-mode with a default to the lowest setting when turned on. I now have it working closer to the way that I want it to work. Thanks.
the 1A is cool white and is brighter than the 3B neutral white. however the cool white light get trapped in the atmosphere easier than the neural white which may reduce throw.
Does anyone know if it’s possible to either extend the turbo timer from 45 seconds to longer, or turn the turbo timer totally off using the Astrolux C8/ BLF A6 UI?
I would like to either extend it, or turn it off on a BLF A6 I have and an Astrolux C8 I have on order.
I know the A6 heats up quickly, but the C8 has much better heat sinking.
My custom Convoy C8 from MTN Electronics doesn’t require a turbo timer, because it stays cool enough with a MTN 17DD driver and XPL-Hi on copper, with spring bypasses.
Unfortunately, no. Unless you get some fancy gear to re-program the firmware. But for the general user, you’re stuck with the 45 second turbo timer. IMO, that was an oversight in the Astrolux C8; they should have increased it to 3 minutes, or removed it entirely.
