LG 18650 HB3 1500mAh (Gray)
Official specifications:
Nominal capacity: 1500mAh
Minimum capacity: 1500mAh
Nominal voltage: 3.65V
Standard charge: 750mA, 4.2V, cut-off: 50mA
Fast charge: 4000mA, 4.2V, cut-off: 100mA
Standard discharge: 300mA
Fast discharge: 10000mA
Max. continuous discharge: 22000mA
Discharge cut-off voltage: 2.5V
Cycle life: 400 cycles to 75% at 10A discharge
Operating temperature: Charge 0°C ~ 50°C, Discharge: –20°C ~ 75°C
Storage temperature: 1 month: –20°C ~ 60°C, 3 month: –20°C ~ 45°C, 1 year: –20°C ~ 20°C
This is a high current cell from 2012
The capacity is on the low side and the curves do not match, I wonder if it is due to the age of the cell.
It can still deliver 20A, but with some voltage sag.
Conclusion
For its time is was a nice tool battery.
Notes and links
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
Compare to 18650 and other batteries
