Mmm, had to order one for a :-) gift. Host only, will be powered by an H1-A with a CRI90+ XHP50. For the price difference, Simon will add a requested 16mm 5050 DTP board, holster, diffuser and gift box. :LOVE:
I replaced the stock 3/5 mode convoy driver in an aluminum S2+ with an A6 driver. It works.
I’ve paired mine with a SST-40 emitter on a DTP copper MCPCB. Rather than bypassing the tail spring, I doubled up the stock spring with a smaller phosphor bronze spring inside of it. On turbo, with a 30Q or an Aspire 18350 it is very bright and it heats up a lot, fast.
It’ll be better with a copper host, probably, but keep in mind that when it warms up, the click timing on the A6 driver gets wonky. It becomes almost impossible to reverse with a medium click, and half-clicks have to be fast, or the driver will get even more confused. Mountain electronics’ version of the driver uses better components and suffers much less from this problem.
I love seeing all the opinions, some closer to truth and some pretty outlandish.
FWIW, pure 100% oxygen free copper is orange in it’s raw state, bright beautiful orange. So is Tellurium Copper. Don’t believe me? Cut it on the lathe and see…
The pink hue comes from handling it….a reaction to the oils in your hand.
Pretty sure SinkPAD lists their copper stars at nearly twice the thermal capacitance of their aluminum stars, not 30% better. That should be worth something, considering the source. (Al’s 210.0 W/m.K, vs Cu’s 385.0 W/m.K) At 210.0 W/m.K * 30% the result would be 273 W/m.K, obviously copper fares much much better at ~83%+ gain over Aluminum.
I have a Hoop pill waiting for this light. Triple something or other it is!
And I also just read recently that the anodizing gives Aluminum it’s thermal emissivity, the dye to change it’s color adds nothing… it is, after all, just dye in microscopic amounts…. (Type III being better than Type II as it’s a deeper ano)
Thanks JDub, and Simon, appreciate the willingness to please.
I can’t argue with led4power’s formula’s and calculators, but I don’t spend the money on Tellurium copper for no reason, or just because it’s pretty or heavy. My lights built with heavy copper pills maintain their output in the light box for longer times. I did the C8 Trifecta on this years ago using copper heat sinks from ryansoh. It was clearly obvious how much difference the copper pill made over the aluminum one.
Let us not forget, cooling the emitters is mission critical, not keeping our delicate fingers comfy.
Might also point out that a full copper light heats up everywhere, get’s hotter in your hands AND heat’s up the cell inside a lot faster. Not necessarily a good thing, in some ways…
Edit: Not trying to be critical in any way, honestly, but I’ve built almost as many lights as led4power has posts in this forum! For the most part, extreme hot rods every one. Wow, how the time flies!
You’re right, I used the light’s volume instead of its surface area when estimating the radiated heat :person_facepalming:
I would’ve guessed for sure that convection and conduction do way more to transfer heat away. But of course it would be boring if I didn’t learn anything while being here
Like I said, scour it under running water, before it gets the chance to oxidise (which happens almost instantly). It’ll be a salmon pink. Within seconds of exposure to air, it’ll have already turned that characteristic “copper color”.
It passivates almost instantly, so cutting it on a lathe, scouring it with steel wool, anything in air, and you’ll never see it in all its pink glory.
Take a slab of pc board, a Cu-bottom pan, etc., and try it.
So if something Cu is pickled and immediately coated, it can be a nice pink color.
So when it’s spinning on the lathe and you’re cutting off the oxidized layer and watching the true nature of the metal spin around, you see it immediately, before air gets to it, under the oil, orange.
Maybe tinged by oil, maybe at higher heat, etc., sure, I’ll believe you when you say that’s what you see, but just try what I suggested. Take a rather large flat(ish) piece of Cu, and under running water give it a good scour. It’ll be a bright salmon-pink. I’ve seen this. As soon as you stop scouring, even under water, it’ll start turning orangey. That’s how fast the oxidation is.
“Copper just above its melting point keeps its pink color when enough light (the camera’s flash in this case) outshines the orange incandescence color.”
Hmm, and
“What you describe as pink is the actual colour of copper. The colour of a clean, solid surface of high-purity copper is typically salmon red. In your case, the appearance may be further affected by the particle size of the precipitate.”
Doesn’t convection have a bigger impact on cooling than radiation? Certainly with a slight breeze it would, but even with still air it must have a pretty big effect. Anyone know the actual number?
Well, as a rough guess, most small lights that are thermally regulated seem to stabilize their output at about 500 lumens, if you tail-stand them. That’s about 5 watts of power, with maybe 50% going OTF in light? If you’re saying 1 - 2 watts of that is radiative, then that leaves only 0.5 - 1.5 watts for convection.
Doesn’t sound like enough. I thought convective cooling would be 3 or 4 times what radiative cooling can do.
It is - at high power, ratio of convection/radiation dissipation depends a lot on input power/flashlight temperature. S2 head has very small surface area,1-2Watts is enough to increase temperature close to 60C over some time.
