I thought there are only leds with two colour temperatures, ~6500K (just a guess) and ~2500K. By changing the output ratio of the two type of leds you can get all colour temperatures in between. I haven’t read anything about this, but this is just how it is in my head.
Pete7874: SKV89:Just wondering how difficult will it be to mod this with some Nichia 219B 9080 or E21A?
According to documentation, there are 84 LEDs inside this lantern, likely using various color temperatures, which is what allows you to select different color temp. Not sure how you could replace them all with a single Nichia LED and still maintain uniform light output in all directions.
Yes, that’s how it works, I believe. I should have written ‘two’ instead of ‘various’.
Interested if it will fit a Protected NCR18650B?
No.
Unprotected button tops fit just barely. The protected ones are too long.
Interested, I take 2 for sure.
Interested!
Interested, thanks
Interested
Interested
interested in 2.
Interested
Thank you for your efforts FreeMe. May I have the code please.
Can I order 2 at same time or do I need to do individually?
Interested.
#85 and #86.
Thank you for your efforts FreeMe. May I have the code please. Can I order 2 at same time or do I need to do individually?
Is it true that protected cells do not fit?
Interested
interested
very nice, interesting !!
interested
Interested
Doesn’t need a protected cell. The lantern driver has low voltage protection and will shut off at around 2.8 to 3v.
