Anyone got a zanflare T1 lantern?
241 posts / 0 new
atbglenn
atbglenn's picture
Last seen: 3 years 4 months ago
Mine can today. I love it! It’s tiny and bright! Build quality is great too. I’ll take pictures later.
Boycott Nike
Pete7874
Pete7874's picture
Last seen: 21 hours 21 min ago
Awesome! Mine is arriving on Sat. It looks like it’ll get here faster than the 18650 cells I ordered from IMRbatteries. Ugh!
atbglenn
atbglenn's picture
I hate to rub it in but my Samsung 30Q batteries also came today from LiIonwholesale. Took only 2 days to get them.
BTW, I’m using a Panasonic/Sanyo NCR18650GA in my new lantern.
Boycott Nike
Pete7874
Pete7874's picture
That is my plan as well.
atbglenn
atbglenn's picture
I don’t trust the included unknown battery.
Boycott Nike
atbglenn
atbglenn's picture
Size comparison. BTW, this little lantern blows away my 300 lumen lantern
Boycott Nike
leaftye
Last seen: 12 min 45 sec ago
The tailcap for the lantern on the right is such a pita.
The low mode should be lower.
hIKARInoob
hIKARInoob's picture
Last seen: 16 hours 11 min ago
Yep. Discharge and dump. Sanyo GA I’ll be using. I think I’ll love the warm white output of this one.
dealgrabber2002
Last seen: 12 hours 56 min ago
Hell yea. Have to lined it up to close it.
freeme
freeme's picture
Last seen: 2 hours 9 min ago
Just spoke to GearBest in the afternoon, they will be able to provide us with  discount for T1cool
1thedeals.comyoutubeAstroluxNealsgadgetsolight
atbglenn
atbglenn's picture
Yep, it sure is a pain in the butt. Plus it uses 3 D cells. I hate D cells. I’m using 9 AA Eneloops in adaptors to power the thing.
Boycott Nike
freeme
freeme's picture
I have those CL25R clone. I think it is better to leave the battery inside and charge with the supplied built-in USB charger? Any PWM for T1?
RobertB
RobertB's picture
Last seen: 2 weeks 1 day ago
I see no pwm on the T1. At least my cell phone camera doesn’t see it like it does with other lights
atbglenn
atbglenn's picture
I love the T1 so much, I ordered a second one!
Boycott Nike
Pete7874
Pete7874's picture
Got it today. Neat little lantern. UI takes a bit getting used to.
Glad to see my unprotected button top cells work fine in it.
RobertB wrote:
The 4th mode is the red light button at the button, which also shuts the light off. 1 press, turns red on, one more press is flashing red, one more is light off.
Also, when the light is on (either white or warm light), long press (2 seconds) of the red light button turns the light off without having to cycle through red light.
hIKARInoob
Let’s see if I can use this as a companion light next to the computer in the evening; I often feel it’s a bit on the dark side and I sure don’t mind a bit of warm white lumens. Cool
This is great, I’m stoked alright!
Pete7874
Pete7874's picture
The supplied 2600 mAh cell has discharge capacity of 2671 mAh according to my Lii-500. Pleasantly surprised, but still, who knows what’s inside?
kyleharleyanderton
Last seen: 1 year 1 month ago
I bought one.. I think wast the first.. lol… but then I was so impressed I ordered a second one!
I think it is the best lantern on the market for the money! Also it can run off of usb power only with no battery which is a huge plus! I also tested the battery and it tested a little higher than advertised. The ability to set a custom tint is fantastic!
kyleharleyanderton
same here
hIKARInoob
It seems that the popularity of this lantern just exploded in a very short period of time. Quite interesting.
RobertB
RobertB's picture
The Fenix CL25R lantern and clones can run off usb only as well. However, the CL25R can only run at about 25 or 30% power, where this Zanflare T1 can run at about 75% power using usb only. Most all flashlights with a usb port can run off usb power.
Pete7874
Pete7874's picture
I was doubting you, so I took out my lux meter, and you are right.
Wonder why that is. The light pulls about 1A at 4V from a fresh 18650 cell. The USB port pulls about 1A at 5.22V.
zelee
zelee's picture
Last seen: 1 week 2 days ago
does this lantern got parasitic drain? if yes how much it draw?
Pete7874
Pete7874's picture
I am seeing about 0.17 mA. At this rate, a 3000 mAh cell would be discharged in approx. 2 years. I would definitely remove the cell before storing the lantern long term.
baldo21
Good question.
I too would like to know.
RobertB
RobertB's picture
Pete7874 wrote:
I was doubting you, so I took out my lux meter, and you are right. Wonder why that is. The light pulls about 1A at 4V from a fresh 18650 cell. The USB port pulls about 1A at 5.22V.
I don’t know why that is. But it’s the same with every usb flashlight I’ve ever seen. Nothing scientific, just simple observation.
I can live with that!
Paul321
Paul321's picture
Last seen: 3 weeks 5 days ago
If this lantern will run (75%) from USB , will it also run off a powerbank?
Suppose I gift this to someone who wouldn’t have any spare 18650 cells.
Paul-
Zulumoose
Zulumoose's picture
Last seen: 1 year 9 months ago
Paul321 wrote:
If this lantern will run (75%) from USB , will it also run off a powerbank? Suppose I gift this to someone who wouldn’t have any spare 18650 cells.
How do you think a simple lantern would tell the difference between a powerbank and any other USB source?
both are intended to be widely compatible in terms of the power interface, so it would be very strange if there were any reason to reject the power source unless it were faulty enough to be well outside acceptable USB voltages.
Beam me up!
Paul321
Paul321's picture
I had made that assumption as well, but I figure why not ask. I will assume the powerbank will then also provide some charge to the 18650 inside the lantern.
Paul-
zelee
zelee's picture
thanks for your answer, good thing i still got some 3000mAh panasonic battery
