Both can be converted, if you can find or make a clicky-switch tailcap which fits. Itāll also need new firmware. I added dual-switch support to Anduril a while back, which basically just makes it turn on at the memorized level when it gets power (instead of blinking and turning off). So, momentary on the tail switch, brightness and extra modes on the side switch.
I find it humorous the lengths people are willing to go to in order to make (or not make) a purchase. Especially in flashlights, have to analyze the heck out of it, yet the closet has how many shirts/shoes/slacks/jackets/coats? We buy a new shirt because we like how it looks, think itāll look good on us, not usually because our closet is bare and we have nothing to wear.
Flashaholics are like that with lightsā¦ ooooooooh! I LIKE that one! Where do I sign up? (Hmmm, could this be why I have 200 lights?)
I NEEEEEED the 10440 version of the GT! I do, I really really do!
Not that your firmware isnāt good (it sure is!!) this āmini-GTā definitely needs the same firmware / UI as the big GT. :heart_eyes:
For the driver, it needs something like the LD drivers from ledforpower. Very nice CC controlled (no pwm!) lower modes and a possible DD or FET like high / turbo mode for ultimate performance.
This mini version looks great! Though it could be a little bit bigger. :smiling_imp:
Really love that it has the same looks as the big version. But the fins could have been a little bit smaller and one extra wouldnāt hurt. (as with the big one :sunglasses: )
I like it that flashlights are starting to use the 21700 cells but an 18650 version makes still sense.
Is there any idea of runtimes on high/turbo? Will it have a step down? Iām always frustrated by specs based on short turbo modes, the real assessment should be lumen/lux at 10min mark
If they continue to run NarsilM then it will be ramping based. You can adjust to whatever brightness level you desire. I think itās 150 steps over 2.5 seconds, but looks like smooth ramping up and down.
You can turn off the thermal protection all together or just set it to the temperature you desire. You can even do timed stepdown if you prefer.
NarsilM v1.2 is the same as in the big GT so you can do all the same stuff. Even switch from ramping to discreet steps. You can have anywhere from 1 level to 7 levels. Itās all programmable.
Great answer Jason. I guess I was thinking one of the maths wizzes would be able to do an estimate runtime - I was amaze someone way able to assess the max kcd based on the head size? Must be some crazy parabolic analysis haha
Assuming the internal mass of this light is the same as a C8, then we can ask someone with a C8 that has a fet driver running an xpl or xm-l2 at about 4.5A what kind of runtimes they get on turbo.
A stock C8 has a 2.8A draw and turbo does not effect it greatly. Thatās just 10 watts.
The mini GT should be around 18 watts. Maybe someone can chime in about the thermal limits.
I think the reflector size is also about C8 sized and just as before, Iām sure there are people running xpl-hi emitters in them that can give us a close approximation of the candela.
So thereās no real math involved, just comparisons to similar lights.
