Got a gallon of WD-40 and a SureShot Sprayer for the WD-40. It works much better than the standard aerosol cans for my needs. I’m using it to coat my drill press exposed steel surfaces and any steel tools that may rust in my garage. It has a much wider spray pattern and finer mist than the aerosol cans. You simply fill the can three-quarters full, and pressurize it with 120 psi and you’re off and running. It works great.
Ordered my 5th Brickwall Filter. I’ve been using these to protect my electronics since the mid-1990’s. Never once had a failure with anything protected by one of these devices. Trust me, it’s light years better than MOV protected surge protectors. Not inexpensive, but it’s cheap if you have expensive equipment that needs to be replaced if there is a major surge from a lightning strike. That said, it will not protect against a direct strike, nothing will.
I really like it. Right away tested some switches and leds and will be really nice for future projects that I have in mind. I got it from Banggood and it came in 11 days. I went on their chat help and asked if they would give me a coupon for this and they did and price dropped to $76.99 so I grabbed it.
Update: Voltage holds steady when in increments of 0.1V but when using 0.10V it swings about 0.15 and then settles between the 0.03 range after a short while.
I went to Home Depot today to buy some Top Soil. But the impulse shopper that I am, I bought this Dewalt bit set on sale… To be honest, I forget what I paid, but it was cheap!
