That’s what I’m pointing out, nobody in this thread has confirmed they’re affiliated and certainly, nobody has confirmed the “factory” store is genuine and not a fake. There’s no links to the factory store from the Liito Kala site, which suggests that it’s a fake store.
That’s a bit of a leap of logic - just because both stores are using the same images, doesn’t mean they’re connected, or that the products in the image are fake - it could be that there’s a different type of genuine Samsung battery which does look like that, even if the items most people have received turn out to be fake.
That’s not how it works - different retailers on Aliexpress use different payment methods, some use PayPal and others don’t. The fact the store you bought from doesn’t use PayPal and the official Liito Kala AliExpress store does, may be further evidence the factory store is a fake and isn’t affiliated with Liito Kala.
PayPal won’t care too much about the claims from AliExpress, it still makes it profit, it’s the retailer which loses the money from a claim.
Well yes, it looked too good to be true and it probably was.
I think the links should remain so that the history remains intact. Too many Ali vendors with similar names. It gets confusing and the links provide a way to verity which vendor. It might be a good idea to post a warning above the original OP saying some members are reporting that the cells they have received are not the same as advertised in the below links and that we are awaiting more definitive testing results.
Let's say you and maybe others too presumed they were reputable.
Advice: extinguish expectations, presumptions, etc.
Do you actually know actual China inland wholesale/trade factory prices for these cells?
As far as my understanding goes, the only univocal identifier for AliExpress stores is their store number. Is store number 217753 the store you are referring to?
Store number 1721160 first named itself (or as far as I am aware of) as “Colaier Direct Sales Store”, later they changed their name to “AM battery Store” and now they're called “liitokala 0fficial Store”. All names exactly as I have written them.
Agree, but store numbers and or pure & shitless links. Format: https://www.aliexpress.com/store/STORENUMBER
The “www” can be changed with locale prefixes (es, de, ru, etc.) for translation but please avoid them here.
I’m beyond frustrated. Have no clue how to post a question . Just recieved my blf gt. Can I use my Tenergy tn 261 charger to charge batteries ? Is 3500 mAh 3.6 volts same as 3500mah 3.7 volts
Used my LiitoKala Lii-500 to analyse the six Q30s 30Qs just received from the AliExpress LiitoKala Factory Store, and got the following results (in mAh):
2935, 2825, 2899, 2962, 2963, 2908 Average = 2915.
They have four fins on the positive end which indicates that they are NOT Samsung Q30s 30Qs.
The results of primitive load tests I did with one of the LiitoKala Q30s 30Qs and a Samsung Q30 30Qs I received from Orbtronics in May is illustrated in the line graph below.
The A6 stayed in Turbo mode for about 35 seconds and then dropped down into High2 for the rest of each minute. After the flashlight was turned off, the battery was removed and its voltage tested. This was done 66 times for each battery. It took almost two hours to test each battery.
it seems to me that the Orbtronics Samsung Q30 30Q and LiitoKala Q30 30Q performed about the same in this primitive test. The LiitoKala battery came out a little ahead but this is probably because it was charged to 2935 mAh and the Samsung Q30 30Qwas charged to 2828 mAh. The LiitoKala Q30 30Q will probably not be a bad battery for my application if it holds up to the test of time.
@ActiveAI, do you have a way to test high drain cells?
Because there are 10A 3000mAh cells on the market, and they probably used it to fake the 30Qs since not many people have the equipment to test cells, let alone at >10A.
No sir I don't. I am fairly certain that the max current drawn by the A6 is significantly less than 10 amps so your premise is quite valid. The only thing my test shows is that the LiiKola Q30 30Q can power an A6 flashlight. Perhaps lumen output should be tested to see if it really matches the Samsung Q30 30Q in performance.
I don’t mean to be picky, but some people not familiar with these batteries may think you are referring to a battery other than a Samsung 30Q, since you refer to it as a Q30. Just thought I’d mention it.
BlueSwordM, do you think that the SM8124A Battery Resistance Voltmeter Internal Impedance Meter discussed in this BLF thread could provide the resolution to differentiate between a real Samsung 30Q and a re-wrapped 10 A, 3000 mAh 30Q fake? According to this data sheet, A real 30Q should have an internal impedance of ≤ 26 mΩ. A 30Q fake would have an impedance significantly higher. Right? Thanks!
GreenLights, thanks for pointing out my 30Q typos!
That doesn’t really apply for newer cells. We were talking above about how cheap over the last year the 25 r has become but it’s been out for several years. 30q and vtc5 came out to the public in 2015 I believe. There’s still a premium price on them and hg2 because that’s what the world is purchasing more then the older cells. The he2 and he4s are coming way down in price as well with the 25r. Even the 20r is down to about 3 dollars a piece now in small quantities
