Review - Imalent RT70 XHP 70.2 5,500 Lumen Monster!!!
Thanks. I made lots of photos, are you wanting more closeups of the lanyard? If so confirm and I’ll post some
:person_facepalming: Terrible tint shift.
Mike
Thanks for reading. A shaved dome would have really extended the range closer tot eh 903m mentioned. Still a great flashlight in my opinion as it puts out so much light. The Acebeam K65 would be an awesome one too I suspect.
I’m not an expert on Tints to be honest so not sure how to respond to the comment
Can you check to see if the bezel is glued. Remind of a slightly larger head mto7s with charging. If the price comes down about 30 dollars eventually I’ll get one.
Just tried and it seems not, however it requires lots of effort and decent gripping/rubber gloves to remove. I managed to turn a small amount with bare hands.
Great review. Can turbo be memorized?
Yes, please! :slight_smile:
That sounds good. Thanks for testing it.
Just tested, seems not
I wonder why they went with 4 parallel instead of 4s. With the haikelite version of this light 4s the voltage never drops enough so you get the full 5000 lumens until the batteries are depleted. Just seems odd they would choose a boost driver when they could have uses 2 or 4s
I guess with 4p there would be plenty of amps between the batteries for the boost driver for most of the discharge
A german friend measured his with ony 3200 Lumens
5500 manufactury spec is way too much from what it delivers
If I’m not mistaken hasn’t a good bit of imalent lights been a good bit underspec? Maybe a couple other people can test them. If they all test like that then we know
I dont have the equipment to measure lumens however with my ceiling bounce test it blew away other flashlights that I’ve tested before. The outdoor performance was amazing too, it’s significantly brighter than anything else I’ve tested. I cant be sure that it is above 5,000 but it wouldn’t surprise me if it was thereabouts. What batteries did your friend use?
I’m interested in lexels response. But just my opinion if lexel says it underperforms I believe him 100% that guy knows his stuff. And has contributed so much info to this forum. Even if yours made 4000 lumens 5500 wouldn’t seem a whole lot brighter to the naked eye. Even if he used crappy cells which I highly highly doubt. For test everyone uses high drain cells. Even with crappy cells as long as they can do 4 or 5 amps it would power it long enough for 30 seconds on Max. I doubt it’s drawing more then 20 amps. Probably not that much.
From what I’ve seen on other lights from imalent they never reach their specs. Look for yourself on the last 4 or so high powered lights. I’d still like to own this one though even if it under performs. I’m sure lexel could design me a driver for it. It’s just to expensive right now. When the mt07s can hit 5000 lumens for 46 dollars. And has 4s driver in it. Which means it gives that 5000 lumens until the light shuts off. The voltage never drops low enough to not provide full power. Like with 2s2p drivers. The one thing I like about this head is bigger and the bezel isn’t glued with a shaved dome and a lexels driver this light has major potential to be a monster. Like 7000 to 9000 lumen monster
You questioned whether/not it be AR-coated glass. If it’s hideously green, it likely is.
I actually don’t use some lights anymore because of that sickly green tint. It nasty.
But yeah, while I’m not so much a “tint snob” (getting there, but not quite yet), I despise green-tints. It’s even worse than Angry Blue™ or Angry Purple™.
So, yeah, green is a sore point to a lot of people, myself included. It could ruin an otherwise amazing light.
Dunno about anyone else, but I get squeamish with even a 2S arrangement in an L2 using unprotected cells. 4S seems that much more to go off-balance with whatever cell might be the weak link. And protection needs to be high-amperage to not also be the limiting factor.
Not as bad as you think. I’ve had a cell not make contact and it ran off 3 cells. Before I removed those spacers it just effected the run time. Unless your over heating the cells to 150c all that will happen is shortened run time. The driver won’t get enough voltage it runs what it can until it can’t. I had to remove the spacers to get proper contact sometimes only 2 would make connection when it dropped out of turbo in a couple minutes I could tell something was wrong. Cells weren’t anything past warm they just gave what they could. Lithium is safer then people give it credit for. Worst case scenario for your name brand cell is a vent, no flame or explosion. Direct short no flame or explosion. Over charged at 12v and 10 amps for hours same result. Heated to 150c for hours at 5c per minute no flame no explosion. Shaken violently and dropped on oak boards. Crushed laterally and vertically. No flame or explosion. Every spec sheet has the results of the test for the cell. Pretty much have to throw them in fire. Get them around 450 degrees Fahrenheit and you’ll get a nice bang. So I don’t worry to much. Even with my 2 series 6 amp L2 with dedomed xpl v6 1a Just stick with name brand cell that have gone through the united nations regulations for safety.
Example people freak out when a cell goes to 2.5 or lower. Most LG cells get there mah rating by being discharged to 2.0 volt. In the 25r spec sheet they pulse discharge it at 30,45,60,95 amps and do a cycle life test and they discharge it to 1.5volts each cycle. I’ve recovered hundreds of 1v cells out of tool packs as well with no problem use them a couple hundred cycles and recycle them back. The hype doesn’t live up the real life. When there is a incident they make as much hype they can about it. And it’s “usually”cheap old technology Chinese cells that cut corners andbhave no cid or ptc inside the cell. Even with the dangerous Chinese cells. To only have a handful on instances yearly to the amount of lithium batteries and devices is less then a .001 failure rate. To the billions of batteries made yearly
The only cell I’ve had a problem with was a Imedion nihm with about 30 cycles on it. Turned my nitecore ea41 on low about 2 seconds later it vented and bubbled my switch up. I’m talking the lowest mode the moon light from off button. I was pissed and never bought that brand again.
Was that for me or someone else?
I’m not concerned about having a Li cell go supernova, mainly just ruining it and making me buy a new one. :confounded:
Figure if anything, it’d just vent and blow out the switch-button or something.
I never understood the big fuss about how far a cell gets discharged when rating its capacity. I’ve watched my almighty and not-quite-almighty chargers run down a cell for hours as it hangs in the upper-3s for so long, but from 3.2V on, it nosedives, and from 3.0V down, I can actually watch the voltage-readings decrease in realtime. So out of, say, 3000mAH cutting off at 2.8V, discharging it a whopping 2min more down to 2.5V (or 2.0V) might scare up a few dozen mAH, but that’s it. To me, it’s statistical noise.
But, after having weak-link alkaleaks take a dump in my lights after getting reverse-charged, etc., I just plain don’t want to brick a perfectly good Li cell by running it down so far. A Crapfire cell, who cares?, but a nice shiny 30Q or VTC6? Nah.
