[REVIEW] ArmyTek Wizard Pro V3 *(Written + Video/Photo)
10 posts / 0 new
liquidretro
Last seen: 6 days 20 hours ago
This light was provided by ArmyTek. Use the coupon code RED for 10% future orders on ArmyTek.com
Video Review
Complete Photo Galleryhttp://imgur.com/a/nEa3p
This is my first ArmyTek light and after having it a few weeks and using it frequently, I don’t think it will be my only one for too long. Flashlight enthusiasts are quick to recommend the ArmyTek Wizard line of right angled lights and headlamps for a variety of uses. I am glad that ArmyTek sent me one for review so I could experience why it’s one of the most recommended brands out there. I can clearly see why. During this review I will be comparing the ArmyTek Wizard Pro V3 with my recently reviewed Olight H2R. Both are headlamps of very similar size, using the same LED and similar battery sizes. Comment down below and let me know what you think of this light.
Headlamps are useful not only as a headlamp, but in this case as an EDC, when repairing cars and around the house hold. Not only will it tail stand but it will stand on it’s head or on either of the sides. A light like this is useful for strapping onto your chest, or straps on a backpack or tent.
Design & Coating
Size wise this is almost identical in length to the Olight H2R, and it’s very similar in diameter too. http://imgur.com/H0ayz0v With the more square head it’s slightly larger in the pocket. Weight wise without batteries they are 2.85oz for the Wizard and the Olight H2R is 2.22oz. Here is a picture where I lined up several similarly sized lights so you could see the size. http://imgur.com/Ma0FPPa
When I first got the light I was worried that the button on the side of the light would be a problem due to how it sticks out of the light. However it’s a firm press and has not been an issue other than the one time I was laying directly on it. The button is translucent and has a multicolored LED underneath that it uses to display information such as heat, mode, etc.
This light is coated in a mat black finish that is slightly grippe. It’s a finish I have not seen on any other flashlights. The one bad thing about this coating is that it does show scratches and abrasions worse than normal anodized aluminum. I keep my phone and light in the same pocket usually, and have noticed it seems like I have more wear on the coating then normal, some paint seems to wear off my phone case and transfer to the body of the light. Most of these rub off with a little water.
The design of this light has a few aggressively shaped areas that I find attract more dust and pocket lint than normal. Up near the head there are several sharped cooling fins, and between these they attract a good amount of dust and lint. Then at the bottom the transition between the body and tail cap also collects a good amount of dust/dirt around the first oring, the good news is it doesn’t get beyond this point. I think that’s the purpose of this dual oring is to provide water and dust resistance even when the tail cap isn’t 100% screwed on like if charging or in manual lockout.
This light is a little aggressive on the labeling in my opinion. I prefer a flashlight with minimal labeling and this one doesn’t get my stamp of approval in that regard. It has labeling on top, on the side, and around the tail. It’s larger white letter on the black body do stand out.
Performance
This light uses a Cree XHP50 and combined with its diffused TIR style glass lens it’s primarily a flood. This one is the white variant and it’s fairly neutral but not warm. ArmyTek lists it as having a 70 degree hot spot and a 120 degree spill. Range of brightness is anywhere from 0.15 lumens on firefly 1 to 1800 Lumens on Turbo. Run times range from 40 Days on Firefly 1 to 1 hour on Turbo 2 (if proper cooling is supplied).
Modes
If you are familiar with other recent ArmyTek lights then the interface is the same as those. If you are new to ArmyTek like I was there is a bit of study needed. The entire 3rd page of the manual covers how this light operates. I am not going to go over everything in this review but will go over the high points. This light is organized into 4 mode groups. The brightness in each sub group is memorized
  • Group 1 – 3 Firefly Modes
  • Group 2 – 3 Main Modes
  • Group 3 – 2 Turbo Modes
  • Group 4 – 3 Special Modes
From off
  • One click turns the light onto its previously memorized mode and brightness.
  • Two clicks turns it onto the previously memorized brightness in main mode.
  • Three clicks turns it onto the previously memorized brightness in Turbo mode.
  • Four clicks turns it onto the previously memorized brightness in special modes.
    Long pressing the button from off cycles through the available modes Firefly through Turbo 1.
From On
  • One click turns the light off
  • Two clicks turns from firefly to main or main to firefly or special/turbo modes to main mode.
  • Three clicks goes to turbo mode
  • Four clicks goes to special modes
2 Philosophies of use – General and Tactical. General is a normal flashlight, click the button and the light stays on. In Tactical it turns the button into momentary, so the light is only on when the button is pressed. To switch between them you unscrew the tail cap by ¼ turn and then press and hold the button, while screwing in the tail cap.
*Battery Level Indicator *- Uses the LED under the button to flash a series of colors every 5 seconds. Green is between 75-100%, Yellow is below 75%, Double yellow, is below 25%, and double red every second is below 10%. The light doesn’t do this in Firefly mode and you can turn this feature off by a series of button presses and cap rotations.
High Temperature indicators – When the light reaches 60C brightness decreases in small steps to cool down.Once cool it will step back up to deliver the most light possible. Timed step down is not used in this light. As temps increase you get a series of LED color indicators on the button. Warning is 3 orange flashes, at critical temps you get 3 flashes in one second.
Indoor/Outdoor and Beam Shotshttps://youtu.be/3Kc_LjbqV3c?t=11m31s
Charging system/battery + Parasitic Drain
Having onboard charging of lithium flashlights isn’t anything new. Lot’s of manufactures do this in a variety of ways. You have seen me talk about Olight’s magnetic charging in past reviews. More recently the concern about live contacts and the dangers of potentially shorting the battery have become more vocal. The ArmyTek system was designed from the beginning to alleviate these concerns and it’s one of the best systems out there for this. Let me explain how it works.
The Charging cable itself is white, and uses USB on the input end. On the other end is a magnetic connection with several LED’s inside. The tail cap has a large recessed center pin and a smaller outside ring. To charge the light you need to slightly unscrew the tailcap. Due to how it’s anodized when it’s tight it breaks the circuit. Unscrew it a little and the circuit is complete and the charging begins. The LED’s are solid red while charging, Red and blinking if there is a problem (Forget to unscrew the tailcap slightly?) and solid green when charged. They also use a diode in the tail cap to prevent short circuiting via the exposed tail caps should you forget to screw in the cap after charging. The other big benefit is that you can charge any normal battery that fits. No proprietary batteries! The downsides to this system is that it’s a little slow to charge by modern standards. I measured it at 0.7A when the battery was at about 40% capacity and charging. If the battery is discharged a good amount this means charging via the built in charging may take several hours (5+). You must lay this light down or stand it on its head when charging. That’s one place where I do like the Olight charging system better.
Included was an ArmyTek flat top cell without protection. It’s recommended that you use a battery that can maintain 7A discharge in order for Turbo mode to work. Parasitic drain was measured at 0.05 mA.
Thermal Management
The thermal management in this light is active. Using Turbo for instance the light will provide as much light as possible until it gets to 60C and then it will step down the light giving it time to cool, and then it will power up again to deliver maximum possible brightness assuming the battery has enough voltage. So if you are in a situation where you have a fan or wind cooling the light it will run brighter longer. During my standard test, at 1 minute during Turbo the light reached 111F. I don’t have the equipment to test and graph the step up and down but I can show you with a glass of ice water.
I don’t often write about the manuals of many flashlights, but in this case I want to say it’s the most complete manual I have seen on a flashlight. It does a good job of explaining its features and has great grammar and spelling. This isn’t a poor translation, I believe it’s written by native english speakers. I think this is a benefit from this flashlight being Designed in Canada and not overseas. I highly recommend a read through or two of this manual to better understand all of it’s modes and available options.
The packaging is a nice white, retail box with a few key details on the outside. Inside is a plastic shell that holds all the goodies. Inside you have the flashlight and an Armytek branded high discharge flat top battery, extra orings, headstrap, handstrap, nylon plastic cradle, and the manual printed in color.
As a Headlamp
Some assembly is required with the headstrap. The manual has a section with diagrams that shows how to set it up which is nice because it was a little confusing. I decided to install my headstrap without the over the top piece. I didn’t find it was necessary with the weight of the light when I was using it on home repairs, and an oil change during my testing. It also comes with a handstrap. I didn’t use this during testing but it’s a nice touch. I could see attaching it to the strap of a backpack, or for use when running. The straps themselves are an elastic cloth that seem pretty sturdy. They are comfortable to wear for extended periods of time. The plastic cradle is a nylon I would guess as it’s pretty flexible. It has cuts in the top, and both sides to make it easy to remove. My one negative is that when mounted on the strap the mount itself can slide around pretty easily instead of staying in place on the band.
As an EDC
I was skeptical at first of carrying a right angle light as an EDC but after the Olight H2R it worked pretty well. The Armytek Wizard V3 is even better due to it’s pretty fantastic clip design and button. The clip might be my current all time favorite of any flashlight I own. It’s deep enough carry, but sticks out enough to easily go on many different types of pockets, or bag straps. It’s rigged yet flexes if needed. My only wish is that it was parkerized black or cerakote instead of a polished tumbled finish. It takes quite a bit of effort to pull the clip on or off the light and it does leave some light scratches on the finish. It seems to rub off though. The clip is not fixed in place so it does rotate if you want it to. The button is proud and protrudes from the light a decent amount. I have had it come on once by accident in my pocket but that was only after I was laying on that side of my body. Due to the smart modes on this light, it didn’t come on in turbo so burning myself or clothes wasn’t a problem. The light does offer lockout if you unscrew the tailcap slightly. I will also add that due to the charging system I covered above there is no worry about shorting the battery while carrying the light in your pocket due to a diode being used and the disabling of the exterior contacts when the cap is screwed on tight. The light also features a pretty strong magnetic base that has no trouble holding the weight of the light to a metallic object securely.
Summary
The Armytek Wizard Pro V3 is a fantastic headlamp and EDC in my opinion and testing. It’s peak performance isn’t quite as high as the Olight H2R but it’s advanced mode options, advanced thermal managements, and well thought out safe charging system all for a slightly lower price than the competition make it a very good choice for a fancy headlamp, and an 18650 floody EDC option. The Olight H2R has a more simplistic mode map, but also doesn’t do nearly as many things or has as many modes. Being my first ArmyTek light, I found the modes took some study to fully understand and remember but once I did they made good sense. I think this makes a fantastic choice for a headlamp but can also be used for an EDC, or general purpose light.
Pros
  • Active thermal management allows the light to be the brightest it can be but keep temps safe. Allows up and down management of lumens
  • Safest built in charging system, works with any 18650 battery that fits.
  • Very well built with an excellent 10 year warranty
  • Excellent pocket clip for EDC carry
Con’s
  • Exterior writing on the light is more than I like to see.
  • The modes are a little complex without first reading the manual. Once you understand they are very logical.
  • Not the fastest built in charging system but probably the safest
Video Reviewhttps://youtu.be/3Kc_LjbqV3c
Up Next is the Acebeam EC35 NW
Let me know what you think of linking photos instead of embeding them.
Edited by: sb56637 on 09/02/2017 - 12:28
AEDe
AEDe's picture
Last seen: 1 week 1 day ago
The measurements show that in turbo mode it gives only 1600lm
New holder is fragile.
In my Wizard multi color indicator don’t work. So armytek don’t have reliability again.
Large dimensions and weight make on head use not comfortable.
atbglenn
atbglenn's picture
Last seen: 2 years 12 months ago
My Wizard Pro V3 XHP50 with daily use has been dead reliable for over a year now. It’s the previous model without the built in charger. That said, I’m extremely happy with it.
Boycott Nike
will34
will34's picture
Last seen: 14 min 34 sec ago
My Wizard Pro v3 is also about a year old and its been working flawlessly, but the lumens claim are highly exaggerated. Maybe the optic is too recessed or lots of light is being blocked by the bezel. Another thing I’m not a fan of is the “CW” version which is more like 5000K and not the nice neutral type, it looks yellow-green.
Dirt
My wizard pro XHP50 warm is out of commission. Only works in low mode. Was my daily driver. Wery sad, now I use my v2 from cellguy’s gb. I will be replacing this light with another Armytek XHP50 headlight, no doubt. My wizard took ALOT of punishment, drops falls etc. and kept on ticking, til now. Sad but now I get to look for the best deal on another!
scottyhazzard
scottyhazzard's picture
Last seen: 3 years 3 weeks ago
Can the battery be changed out on this guy. Say I’m on a hike and burn through a battery…
"Those who hammer their guns into plows will plow for those who do not."
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 7 min ago
Yes it can.
The battery is replaceable. The battery is not proprietary anything, cough Nitecore Olight, cough.
But seriously, just get yourself a second 18650, and you will be golden.
Dirt
The original battery that came with my light has som serious staying power. Prolly due to an emitter/driver that is quite efficient? I am charging the Armytek battery not nearly as often as my XHP50 30Q.
Majoroverkill
Majoroverkill's picture
Last seen: 1 day 22 hours ago
I just ordered the wizard pro v3 with mixed feelings. I hear its great from some people and others stating that theirs died within a year and trying to get it warrantied is ridiculous. Now I feel like I should have ordered the Fenix HM65R.
Doug S.
Overload
Overload's picture
Last seen: 2 weeks 4 days ago
Don’t wory, you bought a great headlamp!It’s still one of my favorites and I own a lot of headlamps…The warm version has a very nice tint in my opinion!
I have mine 2 years now and haven’t got any problems so far
Also, the armytek performs much better than the fenix and I realy like the UI
A minus is the very slow charging of the armytek,I assume the fenix will charge much faster with usb C port
