The cross section can;t really show it, but the shade would definitely need either one or two index locking notches at the head area to lock it from turning. (Same goes for the base)
That tint ramping is definitely in line to be added, as this cross section is just the design of this prototype being tested. All it would need is the change to six emitters, ( three 3000K & three 4000K LEDs) and the addition of a third wire lead from the driver.
Thanks for mentioning that to remind me i missed adding that to the drawing. i did forget to add the upper rubber gasket/o-ring to the head & the small o-ring to the center bolt. (next updated drawing will have those)
I was rather hoping for 3000K to 5000K, because that would cover everything I ever do with artificial light, from reading at night to workshop stuff, respectively.
I understand that LEDs arenāt always available with high CRI at the cooler colour temperatures, though, so no worries if thatās the case. High CRI is more important to me here
Ditto on that. 3000 to 5000 would keep far more people happy than 3000 to 4000, without losing anything or costing more I suspect. Look at the reports on the Zanflare T1 that have come in recently, thus far there seems to be a preference for the two extremes rather than for a level in between by those who have been playing with them.
@Zulumoose, that is easily done. There have already been tests of the 5000k LH351D, so just asking Thorfire to put in 3xLH351D 5000k 90CRI and 3xLH351D 3000k 90CRI is really easy.
The reason we considered only 3000k and 4000k options were because DBSar did not test them.
If i had some LH351 high CRI 5000K LEDs i would test those too. Right now i am testing the 3000K & 4000K because i have these, and modifying the V1 to use four of the 3000K LEDs to be able to do a direct comparison to the 4000K variants while on my trip.
No problem - if thereās one thing Iāve learned through work itās how to point out missing things on drawings. Let me know if you need help or a more detailed cross-section for Thorfire.
Has there been any more interest or discussion on the reflector/deflector to allow adjustment or partial blocking of the output from something other than full time 360 degrees?
My thoughts were that it could snap into grooves at the top heatsink and bottom base plate in order to rotate or be quickly removed.
It would not only block light from selected areas of the 360 pie, but reflect blocked light (white front side black back side) back to lighted areas possibly allowing lower settings to be used for more efficiency. Less output and energy would be wasted if directed only to areas where it is needed and not to unwanted areas.
I have made makeshift shields in the past to block light from shining in certain peoples faces or tents and motorhomes with sleeping people etc. For me, having this all available in a well designed manner on this lantern would be the cats meow. There seems to be occasions where I donāt want or need a full 360 degrees of dispersion whether being carried or hung stationary. 180-270 degrees gets the most use from me.
5000K seems on the cold side for a lantern. Iād think 4000K would be better, or perhaps two 3000K + two 4000K LEDs if they mix reasonably well and donāt end up with color casts that shift over angle.
Does anyone else think the profile just feels tall for a lantern? i.e. the tall base/battery compartment combined with a tiny little lantern top above.
I realize this is based off of an existing light to save time, but the aesthetic feels weird to me.
Iād love to see a smaller version - maybe like 1 or 2 18650ās that sit horizontally to reduce height and size.
