Thanks definitely a better CAD or cross section for Thorfire would be beneficial.
for using four 18650’s to get the run times including the output which is the main intention of this project, its size is not bad really. the current height works much better for resting on tables than any flatter shorter lanterns i have for illuminating a table top, and its already much smaller & shorter than any other factory lantern i have used that can even match half the output of this lantern.
I am interested in one.
For the rubber seal of the USB:
Utorch UT02 and Manker 22 Manker 21 have round ones which are pretty good. They have two sealing lips and they are better than any rectangular ones I have seen.
Maybe we can get the same type of covers for the charging port?
I understand that some people seriously don’t want 5000K LEDs in their lantern, but I still don’t understand why it’s a problem. If the CCT mixing works right (it should, because TK is writing it) then you can use anything from the bottom (currently 3000K) up to the top, but you don’t HAVE to go to the top! You could STILL use only lower CCT. But, it doesn’t work the other way. If there is no 5000K, then those of us who WOULD use it CAN’T.
DBSAR, this isn’t directed at you. I know you’ve already responded that you don’t have any 5000K emitters to test with. This is just a call-out to those who are adamant that the light should absolutely NOT ship with 5000K emitters installed. I don’t understand why they keep insisting on that.
Can you add a 3 minutes versio of sunset? Or 2,5min on a certain level and then dim to zero?
It is nice when you are in a cold tent in winter time and you zip your sleeping bag
Xiaomi has a desk lamp which does color mixing up to 6500K
It’s for to stay awake.
Here is a review from budda
Interested in one
Thanks
Well, you lose brightness at either extreme because you have half the number of LEDs, unless the plan is to make that not happen by limiting the brightness when all 4 LEDs are on so that brightness is constant over color temp. If the color temp is adjustable, I hope it’s done in a way that the light remembers the color temp between power cycles so you don’t have to set it every time it’s turned on.
Personally, I don’t think 4 LEDs is enough to make adjustable color temp work. The two lanterns I have with have many more LEDs and a lot more diffusion for color mixing.
To me, this would be even more reason to make the extremes more extreme. Then, you get a wider range of CCT that still includes all the emitters. However, if you think about a current regulated driver, the only light you’ll really be missing is the difference in efficiency going from one set of LEDs to the other (cooler CCT emitters get more lm/w output) and going from 4/6 emitters to just 2/3 emitters (LEDs are more efficient at lower wattage, so same current going to fewer LEDs will mean higher wattage per LED, so lower efficiency). Those differences in efficiency will probably NOT make a noticeable difference in output as seen by the eye. But, I still want a wide CCT range, because I just do! :innocent:
FWIW I really prefer a warm tint. As others have stated a campfire is around 2000k. I have the bld a6 with the 5a tint which is nice. Cool white lights all seem harsh and cheap to me. But to each their own. Understand that the majority of people want a cooler white than I would. That’s fine. Not asking for a change, just expressing an opinion.
I’m really excited to get one of these. Depending on how it all plays out,final specs and price I could easily see myself getting a second. Is there any projected eta? His summer, calendar year? Probably a bit early to know. Just figuring out my expectations.
qft, I am with you all the way , the warmer the better for me to. I am also wandering if it will have all those special and cool features that fw3a will have like candle-, lightning mode etc. IMHO It s cool and all but unnecessary and kind of stupid in a flashlight but in lantern like this absolutely necessary. This is where I would use modes like that, in flashlight I would never use it except maybe to show of but then again I am not a showoff.
[/quote]
Well you wandered to the right place. AFAIK, the lantern is planned to run Anduril, which is the same program that produces the modes you listed
nember 860 on the interest list for joechina
interest list number 861 for our Black Sabbath fan. :sunglasses:
LOL! Seriously bro, I was just thinking “Man I’m really late to the party on this” And then I saw your post…… No worries. I’m good with being on it for two
Please add me to the list for one of these beauties. Thanks!
Interested in a second one if price is right (#99 on list already).
MCT
UPDATES Cross section of the BLF V2 lantern added. Further field testing going great! photos coming soon. also will have more detailed specifications for the lantern to provide to Barry & Thorfire soon. All we may need is to find someone to draft up a CAD of the lantern in the cross-section drawing below if Barry needs a more detailed version for Thorfire to work on.
Please, please make it a USB-C port. Then you could also use the single port for input and output.
But seriously, USB-C is so much better :heart_eyes:
added at number 862 on the interest list.
MCT
added a second lantern at number 863 on the interest list.
Thinking of doing a video for my youtube channel talking about the BLF lantern project this weekend. It woudl be easier to explain the features of its design. I wil be sending the Cross section drawing & detailed specifications off to Barry this weekend to get it rolling with Thorfire.
sounds like a great idea, looking forward to it. :+1:
