KawBoy, thatās good for a cold winter
Still, it must have been a work to make it fit the S2+ head :o
Nice work all of you And thanks for the inspiration
Back when the Eagle Eye X6 first came out I did the first triple conversion and got hooked. Iāve done so many X6ās now with so many different configurations itās become difficult to think of something new to do with them.
But itās true, you start small and work upā¦ like with most anything.
As I understand it, the S41 was a spin-off of a quad X5 I sent to Neal, back when the X6/X5 was a group buy and just taking off. I built the first quad X5 (I know this as it was a prototype I built it on) that one made 3030 lumens from the 14500 cell. Itās been used to scare Black Bearās off from a camp-siteā¦ the forest ranger was quite impressed as I got the story. Yes, I gifted it to a friend up North.
Once you start, it becomes an addiction, be forewarned!
Awhile back (Dec last year) I modified a friends Astrolux S41 to give him a better tint (heās a tint snob) and while I was at it, I made a copper bezel to go on the copper head section for added heat sinking. He loved it.
For soft aluminium I used a #26 scalpel blade, same for the reflector hole.
There are better tools to use for this.
I just had to put an angle on the lip of the pill to clear the components that side.
Mine were of the very first or early version S41ās and the Noctigon triple board fit with out a problem, I just changed an older one from quad to triple a couple weeks ago, no problem. Maybe something changed (S41/Noctigonās) between the two?
I reflowed a Nichia 219C D240 4000K 90+ CRI emitter onto a DTP copper MCPCB and put it in a āForfarā derivative of the Thorfire VG10 I picked up on Amazon for ~$6.
I didnāt change anything else. The light came with a buck driver. The modes are well spaced, and the UI is acceptable with the forward clicky the light came with.
The most time consuming part was fitting a centering ring and getting it focused. I ended up with the stock XM-L ring, a small 3535 ring that fit inside, both lapped down. When that produced an ugly brownish spot in the middle of the beam, I built it back up with, ultimately four layers of kapton tape.
Iām really happy with the result.
The host is great. The only flaws are a divot in the center of the top of emitter shelf and the low-low-budget logo. With the copper MCPCB and modest power (~10W) I was content to fill the divot with thermal paste. As for the logo, unfortunately, they popped for the cost of laser engraving, rather than just printing, so Iām going to have to take off a bit of aluminum to get rid of it.
This is my third Nichia mod, and my second 90. I have 10 more 80 & 90 219C and 319A emitters, plus some 219b coming, so it wonāt be my last.
My triple SST-40 build is slowly inching forward. In retrospect, Iād have been better off rotating the sinkpads to make the electrical interconnects easier. At the time, though, I was more worried about having to get them aligned properly again.
Iād also have been better off going with my first pass at the interconnects, because Iām sure they were good enough. Instead, I went chasing some mercurial notion of ābetter.ā Iām not even sure what it was ā maybe, in part, ~equal-length circuits through each emitter?
In the end, though, I hoped overkill would be good enough and used the solid 14 gauge conductors from scraps of residential electrical wiring.
To finish up I need to solder copper strips to the big conductors, dip them in epoxy or something for insulation, and then solder the strips to the MCPCB contacts and pot them onto the copper backing disk with some JB weld so I can reflow on the emitters.
Then Iām going to have to figure out and fabricate a spacer. Iām thinking some copper plumbing pipe, probably stuffed with lengths of coper wiring scraps running parallel. Iāll pot it with epoxy and then file and lap the ends flat for good contact with the MCPCB on one end, and the host body at the other.
Good experimentation there though I think you might revert to the dual ring variant.
There is a triple 5050 PCB available from oshpark that might be able to be beefed up a bit but maybe not the right size for you. https://oshpark.com/profiles/scottyhazzard
Iāve been thinking of a small triple SST-40 too, I like them
