(prototype) the GT Mini
1637 posts / 0 new
Angel Martínez
Last seen: 13 hours 56 min ago
Okay. Thank you so much.
lionheart_2281
lionheart_2281's picture
Last seen: 4 hours 15 min ago
Filled out the form, it’s a thrower so it’s gotta be a CW version Smile
Legit question from a non modder: why not use a boost driver and put in a XHP35? Is the emitter too big for that reflector and it won’t be a thrower anymore? Or would heat be the issue?
JasonWW
JasonWW's picture
Last seen: 1 day 6 hours ago
There’s already 3 or 4 lights like that. The price would go up probably 50% or more. I don’t even think Thorfire has a boost driver that can do 30w. I’m not even sure they can build boost drivers, much less one as powerful as they need to exceed this xpl’s output. These are all my guesses.
djozz
djozz's picture
Last seen: 6 hours 39 min ago
^ not Thorfire but Lumintop, but they are also not top of the range in designing their own drivers. I’m still betting they use a TA driver.
JasonWW
JasonWW's picture
Woah, I guess I had Thorfire on the brain.
Lumintop does have a boost driver in their ODL20C. It’s a little bit bigger than this light. About the size of the Utorch UT02. It must be new. It’s got a xhp35-HI and is rated at 2,000 lumen using a single 26650.
What I don’t see in their store is a C8 sized light. Maybe they think the mini GT with xhp35-HI would overlap in sales with the ODL20C.
DB Custom
DB Custom's picture
Last seen: 1 day 18 hours ago
Unless the XHP-35 can be driven at a real-time 2.5A (at the emitter) it can be beaten by a well driven XP-L HI. I got the Lumintop version of the UT02 and it was fairly pathetic so I replaced the 35 with a XP-L HI and used TK’s Anduril, it does 1700+ lumens and throw is around 212Kcd as I recall, like it a lot more this way. (This may be the ODL20C, it wasn’t named when I got it from TK… she sent it to me in a Pringles can so I call it my Pringles Thrower. lol)
Drain on the cell is actually less with the overdriven XP-L and lumens is only slightly less while throw is more, so it’s a win all around to get the nicer UI… or for me it is anyway.
Lumintop is building some excellent lights these days so the Mini GT should be a true win whichever way they go with it.
lionheart_2281
Some interesting info there, thanks guys for explaining
joechina
Last seen: 1 week 6 days ago
giorgoskok wrote:
Maybe another word haha ! Little Thrower (LT) maybe Big Smile Big Smile Big Smile
Mini Giga Thrower is kind of ironic
Most people say 4000 mAh instead of 4 Ah. Wink
joechina
DB Custom wrote:
… This may be the ODL20C, it wasn’t named when I got it from TK… she sent it to me in a Pringles can so I call it my Pringles Thrower.
It’s an intresting picture: A tube which shoots Pringles.
Potato chips all over the spot. Smile
DBSAR
DBSAR's picture
Last seen: 1 day 5 hours ago
i’m in for 1 Smile
joechina
DBSAR wrote:
i’m in for 1 Smile
You must enlist in this thread DBSAR
http://budgetlightforum.com/node/60983
Delta_V
Last seen: 5 months 3 days ago
Do we have an ETA on when info about the driver will be available? That will ultimately be the deciding factor for me. If it’s a FET+1, I’m not sure what this will offer over the D1S besides different styling. But if it uses a buck or buck/boost driver, that would give more stable output and also increased efficiency on intermediate modes. That would differentiate it from the D1S enough that I’d definitely be interested.
joechina
The price off the D1S and MiniGT is the same.
And a buck/boost driver costs more than a FET driver.
So I guess no.
Delta_V
This is also the group buy price, and the retail price will likely be higher, so it’s not completely unrealistic. Plus Lumintop has some recent experience with boost drivers with the ODL20C and ODF30, and buck drivers with the BLF GT. So I was just kinda hoping that they would be able to leverage that so I would have a reason to own both this and the D1S.
dekozn
Last seen: 1 day 13 hours ago
What is the expected throw in meters? I might be interested depending on how far it throws.
Idiot proofing something only creates improved idiots.
spaceminions
Last seen: 3 months 4 weeks ago
As of right now it just looks like a d1s where for $4.95 you can get a different look and a different microcontroller + firmware. If it had a non-group buy price of more than $40 but because of that was able to use a high power boost and xhp35 or something, or even just something different from 1+fet, it would be more attractive.
joechina
What light level do you want on your target?
0.25lux is seen as bright as full moon in a clear night. This is what ANSI use.
A more practical reach is normally between 1/2 and 1/3 of the ANSI reach.
You can calculate it from the candela value 135kcd for the MiniGT.
scr(135kcd/0.25lux) = throw in meter
DB Custom
DB Custom's picture
I hear all these rationalizations and wonder if everybody has 7 of the same shirts, same pants, same shoes in their closet. . . then I realize probably most people actually want a light to do something different as they only have 2 or 3 anyway, but by the time you hit 200 lights in your possession you don’t care what it offers just that it looks different, you know you’ll make it offer what you’re looking for when it’s all said and done anyway. Big Smile
I USED to want something different, then I remember when I had 29 lights and was showing that last one to the neighbor his wife said “29! Geesh! How many lights do you NEED!?” and I immediately said… “30.” Wink
It’s always about the NEXT one, not the last one. LOL
shirnask
shirnask's picture
Last seen: 2 hours 21 min ago
Amen
deleted-200707
Last seen: 1 year 3 weeks ago
my wife says “Ah men!!!” Facepalm
NeutralFan
NeutralFan's picture
Last seen: 3 days 3 hours ago
Good one chinooker!
I’d rather use my flashlight around the house than turn on the lights.
spaceminions
DB Custom wrote:
I hear all these rationalizations and wonder if everybody has 7 of the same shirts, same pants, same shoes in their closet. . . then I realize probably most people actually want a light to do something different as they only have 2 or 3 anyway, but by the time you hit 200 lights in your possession you don’t care what it offers just that it looks different, you know you’ll make it offer what you’re looking for when it’s all said and done anyway. Big Smile (…)
Would you rather to wear the same shirt every day without washing? If not then you see how one light that can be used day after day is different. Also, there’s some people out here who actually care how good something comes from the start, rather than just buying the new shiny thing only to immediately rip the guts out. I would rather like to get one of these, if it’s not going to be identical to the d1s in basically every aspect. See, no matter what random thing I buy, whether it’s an oil lantern, a typewriter, or a flashlight, I expect it to work as well as possible. I don’t buy stuff to sit in a sealed case for 50 years, I buy it to use. So I’d like this to not only look different, but have its own niche.
DB Custom
DB Custom's picture
spaceminions, nobody knows that better than I. All my lights are sitting ready to go with charged cells at all times. They get rotated. Wink
I still do try to keep my lights fitting different roles, so when I’m going to use one I have to pick it for what it does, as it relates to what I’m going to be doing. When I go out, I usually carry at least 3, sometimes 5 or 6, to fit changing demands. Big Smile
Reminiscent of the old saying “Never bring a knife to a gunfight!” Wink
I literally have 3 to 4 lights on my person all day every day, and my Texas Poker is around my neck virtually 24/7/365.
(And once in a while a light comes out of the box good enough to make even me leave it alone. Maybe not very often, but it does happen.)
Eraursls1984
Last seen: 1 month 1 week ago
DB Custom wrote:
…and my Texas Poker is around my neck virtually 24/7/365
Was that machined by Fred of Photon fanatics?
spaceminions
Yup. I don’t bring so many around with me; 2-3 is fine. I do want the out of the box item to be good enough it’s hard to criticize, and I think making this a mini xhp35 light like the bigger sibling could be a neat option.
ToyKeeper
ToyKeeper's picture
Last seen: 1 week 5 days ago
Full details are here: http://budgetlightforum.com/node/19536
DB Custom
DB Custom's picture
Thanks TK. Wink
clemence
clemence's picture
Last seen: 10 months 1 week ago
Very interested with this one. 18650 form factor is perfect for me. 18350 would be awkward to handle with it’s big reflector.
I never like D1S for it’s linear driver and weird looks. I really hope this one uses constant current buck driver and XPL-HI, could be a great host for Nichia 119D.
- Clemence
spaceminions
A buck driver would be equally cool, yeah.
ssschen
ssschen's picture
Last seen: 2 months 3 days ago
I am trying to decide between this light or the Convoy L2 as my next thrower. Since the price of the two is more or less the same (Convoy L2 is slightly cheaper with GB code), would love some opinions.
I already have the following throwers, and I like all of them.
Haikelite MT07S (XHP35 HI version)
Haikelite SC01
Emisar D1S
