With such a large shell, using XHP70.2 is very reasonable
In addition to excellent heat dissipation, LED life can be extended
Have the advantages of throw and flood both
Maintain the same shell design as MT-35 Plus
In addition to black, there are more gray optional, visual will be a little bit of military green
The biggest feature of the MT series is that it can share the battery compartment
He is my brother
Mark
Same shell, using different LEDs
Really a big one
XHP70.2 visual should be natural white NW
4 light cores with even brightness
Boost circuit
LED 12V wiring
MT series shared battery compartment
Green button indicator (breathing) light
Tripod hole, strap ring
Outdoor test:
A total of five levels of brightness, in addition to Strobe, SOS, beacons and keys locked
Modes is practical and the operation is not complicated
When taking a photo, center of the photo set a little bit overexposure only
So the photo does not look brighter than the spot
Was Costen. Dinero. Gelt. Moolaa. Moneeeeey.
āOW MUCH?.
Think Iāll go the shaved 70.2 NW.
Have a Imalent DN35 and a Convoy D6 Was after a D2 for in the middle.
but this looks pretty good.
I could stop at around 20. IF they would stop turning more out all the time hey,
every time you turn around, thereās another ābettererā one on the way.
