Freeme, can you get a measurement of amperage and voltage at the board up top? Looks like a boost circuit running those emitters in series, just wondering what the levels are… no biggie if you can’t but sure appreciate the information if you can!
Edit: Also, can you determine if the bead blasted head is also Titanium or is it Aluminum for better heat dispersion? And is the aspheric glass or plastic? Inquiring minds and all that…
Edit II: Sorry, but are the Nichia’s in the 5000K variant or warmer? The linked pages that show beam color show white but the indication there is also XP-G3 and this is Nichia 219C, thought I’d attempt to clarify. According the Nichia datasheets if the 219C is going to be making 1200 lumens with 4S set-up then the current should be in the 700mA range. This should fare pretty well in the heat department, do you have any feedback as to whether or not it runs on the warm or hot side?
With an Aspheric lense for even flood lighting, this would be perfect for E21A 9080 or Optisolis emitters. Will paint the perfect wall of even HI CRI with perfect tint light for photography.
Would you EXPECT IP68 from this price point? IP68 being the highest rating a consumer device can attain, right? So, seems like at the price point it would be highly unlikely for this one to be able to withstand 1.5M underwater for 30 minutes.
