BLF Interest list for Very High Current Beryllium Copper springs Pt1(ENDED)
I’m interested in 20 large springs and 20 small springs. Thanks BlueSwordM!
You’re welcome skinny_tie.
I do wonder though.
Why did Hank not make a bigger beryllium copper spring? He must know about the demand, no? Or does he think the spring would not sell well?
Or maybe it is just because that at the time the small beryllium copper spring was introduced, there were almost no lights which could take advanatge of their very low resistance except for the Noctigon Meteor?
Or maybe he did just think there was no market for a bigger spring.
Edit: There are a total of 841 big springs and 277 small springs.
If the small springs reach 500-600 springs, I will ping the manufacturer to make a batch of 1000 springs.
The group buy will continue for 3 weeks.
Is there something you guys think I should change about the big spring?
Would you prefer a gold plating instead, and a 1.1-1.2mm wire for even better conductivity? Or a smaller top?
Let me know.
Gold plating will make it corrosion resistant but, how much is that? Is it worth it?
1.2mm (≈1.131mm²) wire diameter will make it a little bit better conductor than AWG21 copper wire. :THUMBS-UP:
Cheers :-)
Yeah I don’t think it is worth it for the additional cost
I will ask if it is possible to use 1.2mm wire for the same cost or not. I don’t think it is going to cost more, if it will cost more at all.
At 1.2mm diameter though, that is going to be one tough spring.
40 + 20
When i have done a bypass on thick springs sometimes its too hard to press after bypass. Not a huge deal i guess but i would still end up bypassing some of these unless it was just as good as 22g wire bypass.
With a 1mm wire diameter, it is better than a 23AWG wire, and a bit less than 22AWG wire.
With a 1.1mm wire diameter though, it is about as good as 22AWG wire.
With a 1.2mm wire diameter, almost as good as 21AWG wire.
So no need for a bypass for once with these springs.
I personally don’t like doing spring bypasses on steel springs. They just suck too much solder, and tend to fail if you don’t have enough experience.
If a bypass is truly not needed even with this length spring maybe thicker is better. Idk. Will be interested to see what the others think
Thicker is always better when resistance is concerned at such high currents we do(10A+).
However, there are design limitations in the case of a compression spring for a battery, mostly memory elasticity.
From the info I have gathered, 1,3mm is probably the limit, but a bit thinner for more room for elasticity is needed. So 1.2mm will probably be what I pick if there is a small cost difference, if any since I’m ordering more than a 1000pcs.
∅1.2mm wire has π(½(1.2mm))² = 1.131mm², with 38% IACS that equals almost 0.43mm² of copper wire.
My Electrodroid app lists 0.41mm² for AWG21 wire, thus it should be a little bit better.
Cheers :-)
I’m in for 20 big, 20 small. Thank you!
A spring is longer run of wire though so the drop is greater. However im not sure how to calculate that when the spring is compressed. Would it take a shorter path or would it have its own resistance? A 22 gauge wire and 19 gauge wire of double the length are almost the same
I'm in for 20 big and 20 small thanks!
You do not want a spring this size in 1.2mm wire thickness, it is too thick, will be mechanically inferior and the coils will get in each others way. 1mm is plenty thick, already thicker than most steel springs the same size out there.
20 small as well. :+1:
I would like to add 20 small to my order.
Change please , not 20 but 30 for me , big size .
Thanks
30 Large
30 Small
OK then.
I will keep the spring thickness at 1mm.
I knew something would be wrong if we increased the wire thickness. Thanks for confirming my doubts djozz :+1:
