Copper S2+ limited edition
598 posts / 0 new
led4power
led4power's picture
Last seen: 3 hours 46 min ago
 It is - at high power, ratio of convection/radiation dissipation depends a lot on input power/flashlight temperature. S2 head has very small surface area,1-2Watts is enough to increase temperature close to 60C over some time.
led4power
led4power's picture
DB Custom wrote:
I love seeing all the opinions, some closer to truth and some pretty outlandish. FWIW, pure 100% oxygen free copper is orange in it's raw state, bright beautiful orange. So is Tellurium Copper. Don't believe me? Cut it on the lathe and see... The pink hue comes from handling it....a reaction to the oils in your hand. Pretty sure SinkPAD lists their copper stars at nearly twice the thermal capacitance of their aluminum stars, not 30% better. That should be worth something, considering the source. (Al's 210.0 W/m.K, vs Cu's 385.0 W/m.K) At 210.0 W/m.K * 30% the result would be 273 W/m.K, obviously copper fares much much better at ~83%+ gain over Aluminum. I have a Hoop pill waiting for this light. Triple something or other it is! Big Smile And I also just read recently that the anodizing gives Aluminum it's thermal emissivity, the dye to change it's color adds nothing... it is, after all, just dye in microscopic amounts.... (Type III being better than Type II as it's a deeper ano) Thanks JDub, and Simon, appreciate the willingness to please. ;)
Specific thermal conductance/conductivity and specific volumetric capacitance/capacity are very different properties of material.
Copper has almost 2x times better spec. thermal conductivity (Sinkpad numbers you mentioned), but spec. volumetric capacitance is only 30% better.
Spec. volumetric capacitance determines how much temperature would rise when material receives thermal energy/heat.
Phlogiston
Phlogiston's picture
Just noticed that these are all sold out now.
Mine shipped this morning, so the three week countdown to here has started. Thanks to Simon Mao and J-Dub74 for making it happen Thumbs Up
Lund1660
Last seen: 1 year 1 week ago
I just ordered but wasn’t sure what options for driver or led was available, what are the available options.
Phlogiston
You can basically ask for anything that’s available in another version of the S2+. You can see the older S2+ configurations here:
https://www.aliexpress.com/store/product/Free-Shipping-Convoy-S2-Gray-Cr...
and the newer configurations here:
https://www.aliexpress.com/item/desert-tan-S2-flashlight-with-XPL-HI-led-inside-and-ar-coated-glass-biscotti-firmware/32820745681.html
Other tweaks may also be negotiable, possibly at an extra charge.
I went with a 7135×8 Biscotti driver and an XPL HI U6-3A LED, along with AR glass and a smooth reflector. Basically copying one of the new Desert Tan S2+ configurations.
patmurris
patmurris's picture
Last seen: 2 months 1 day ago
I’ve never turned a S2 into a triple… What’s the easiest way to do so?
If i could get a triple Nichia 90CRI drop in that works with the A6 driver that would be great.
-X3-
-X3-'s picture
Last seen: 1 week 3 days ago
You have to make or buy a spacer.
Copper is best, aluminum is good…
Kiriba-ru sells some, for a reasonable price IMHO
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
MascaratumB
MascaratumB's picture
Last seen: 2 hours 6 min ago
+1! Bought some from him and I’m happy with those!
I didn’t buy the S2+ copper but this surelly looks pretty!
Modders, show us what you’ll do to yours Evil
Henk4U2
Henk4U2's picture
Last seen: 1 hour 24 sec ago
Was one of the first to order it, but had to cancel because I had not specified led and driver, et cetera.
Apparently this caused the light to re-appear in stock only moments ago. And I (re)ordered the (truly) last one. Sigh…
EDIT: And 15 hours later it is already on it’s way to me Party
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Barkuti
Barkuti's picture
Last seen: 10 hours 29 min ago
Apparently this caused the light to re-appear in stock only moments ago. And I (re)ordered the (truly) last one. Sigh...
Great, doesn't it? Smile
Mine is going to be a custom build with H1-A 3A boost driver and an XHP50 90+CRI G4 35G. Gotta decide if I'm gonna put a 10º or a 5º TIR on it. Up to 1600+ lumens OTF if I'm not mistaken, I could increase driving current a bit but it's going to be gifted to a non-flashaholic lady (a very smart person).
Cheers Party
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
Keanu Reeves may need your help. Join his Telegram channel here.
vinte77
Mines on the way and I ordered it as a host. It’s being kept to build out as a future gift. But if I take a liking to it then I’ll keep it.
Pezo
Last seen: 10 months 3 weeks ago
Barkuti wrote:
Mine is going to be a custom build with H1-A 3A boost driver and an XHP50 90+CRI G4 35G. Gotta decide if I’m gonna put a 10º or a 5º TIR on it. Up to 1600+ lumens OTF if I’m not mistaken, I could increase driving current a bit but it’s going to be gifted to a non-flashaholic lady (a very smart person).
This sounds interesting, please do post about it when you built it Smile
WillyD
Last seen: 1 month 2 days ago
Barkuti wrote:
Mmm, had to order one for a Smile gift. Host only, will be powered by an H1-A with a CRI90+ XHP50. For the price difference, Simon will add a requested 16mm 5050 DTP board, holster, diffuser and gift box. Love
Cheers Party
Barkuti, isn’t the H1-A 20mm? I thought the S2+ used a 17mm driver. I think what you are proposing would be an awesome build, so I’m just wondering how you are going to do it. I might be off on the driver dimensions or maybe there’s another H1-A I’m not aware of. I was looking at the one on KD. Thanks.
Barkuti
Barkuti's picture
WillyD wrote:
… Barkuti, isn't the H1-A 20mm? I thought the S2+ used a 17mm driver. I think what you are proposing would be an awesome build, so I'm just wondering how you are going to do it. I might be off on the driver dimensions or maybe there's another H1-A I'm not aware of. I was looking at the one on KD. Thanks.
Yes, but take a look at Jensen567's S2+ builds. Since I have a powerful hot air gun I'm gonna solder the H1-A to the pill in a similar way (I also plan on slightly biting the H1-A board for the pill indentations).
Cheers Party
timbo114
timbo114's picture
Last seen: 13 hours 45 min ago
I cannot believe I missed this light!!
I certainly hope there is a batch #2 in the works…
crz6662
crz6662's picture
Last seen: 1 month 3 days ago
Shame I have 4 Convoy’s already. Very nice…
timbo114
timbo114's picture
Simon just told me … about 2 months for batch #2
Threadneedle
Threadneedle's picture
Subscribed for batch #2
wiley07
Last seen: 10 months 4 weeks ago
Me to
WillyD
Barkuti wrote:
WillyD wrote:
… Barkuti, isn’t the H1-A 20mm? I thought the S2+ used a 17mm driver. I think what you are proposing would be an awesome build, so I’m just wondering how you are going to do it. I might be off on the driver dimensions or maybe there’s another H1-A I’m not aware of. I was looking at the one on KD. Thanks.
Yes, but take a look at Jensen567’s S2+ builds. Since I have a powerful hot air gun I’m gonna solder the H1-A to the pill in a similar way (I also plan on slightly biting the H1-A board for the pill indentations).
Cheers Party
Thumbs Up Ah, got it now.
vinte77
Wow, I just got the host version and it’s pretty nice. I was planning on gifting it but now I’m going to keep it. Now only if Simon would make 18350 tube for it…
moderator007
moderator007's picture
Last seen: 7 hours 50 min ago
+1 Thumbs Up
mortuus
mortuus's picture
Last seen: 27 min 45 sec ago
Simon better make it the L6 in copper soon.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
mrheosuper
Last seen: 6 months 3 weeks ago
If only he sells them as hosts, a triple nichia 219B rose tint is the best combination
Forgot my pen
cu42
Interesting development -
When I first received my Cu S2+ it had a pink cast. Now that it has been sitting on my desk for a couple of weeks, it has started turning more orangish. It will be interesting to watch the natural transformation of color as time goes by. It has a coating, but it must not be sealed from oxygen.
timbo114
timbo114's picture
A good wipe down with acetone will remove that coating and let that beautiful copper breathe properly.
SKV89
Last seen: 9 hours 52 min ago
The copper S2+ host I received is not pink at all. The feel and weight is very substantial and I think with a copper S2+ pill from kiribaru, it is the perfect host for a 4500k 219B 9080 with perfect rosy tint driven hard.
vinte77
Simon does, you just has to message him. I bought mine as a host.
Minocc
Minocc's picture
Last seen: 12 hours 43 min ago
Mine came in!
timbo114
timbo114's picture
Host or complete light?
