Apologies if I missed it, but where did you get the stainless steel switch?
If your referring to the switch on page 1 of this thread…, they come with the flashlight, I think they are standard on the red and clear anodized s2+.
If, like me, you have one of the S2+ lights with a black metal switch you can buy the stainless metal switches from Banggood and the light will shine through the clear gasket (barely). So my Tan/Sand colored S2+ has a stainless metal switch I replaced and then added a lighted switch to.
Yeah that is the switch, do you have a link on Banggood?
It only works on the ones already threaded for a metal switch though.
Thanks!
So Lexel, are you going to have these switches available for purchase?
Yes… where’s the group buy on these switches? I need at least 10!!! :heart_eyes:
Fully preassembled please!!!
That’s awesome Lexel. Are you planning to sell these?
Will the FET switches also fit in the tailcap of a Convoy C8 v2? Does anybody know how that lights tailcap compard to the one of the S2+?
Convoy C8 v2? Do you mean the new Convoy C8+? if that what you meant… I should have one arriving in few days, I’ll check and let you know.
Just checked with FET switch alone and FET switch + lighted pcb and they all it fit perfectly.
Thank you! Great to know!
This means mine will go in this light from kiriba-ru which uses the body tube of the C8:
Cool, let me know how that works for you,
Has anyone else used this FET switch, they seem not to last more than 2 weeks before they stop working… for some reason the coin cell just craps out. ill Raise R1 value to 4-5kohms to slow down the charging current and see what happens.
The charging current should be fine. But maybe the discharge current stresses the cell too much. The maximum continuous discharge current is 0.1mA.
Try increasing R2, by a lot.
I thought about that as well… but the weird thing is that they just die on there own, the light would be sitting unused for a week with a fully charged 18650 in it, than the next thing I know when I try using it is its dead, the coin cell voltage is at 0. anyway I have some more boards on order, ill increase R2 like you said and see how that effects the battery and the FET gate.
old values showing hysteresis
https://youtu.be/8g3PkN4f5WE
new values, works better
I got a major problem here on my builds I can not firgure out
I removed hysteresis and adjustable reference, but it is still odd
If I put the board on my PSU and it is on I can connect it it is lightning up, reducing the voltage makes it go red and then turn off
But when I increase the voltage it does not turn on anymore or go from red to the other color
I measured the voltage on the ina+ and b+ and it is higher than the reference, but I got to disconnect the PSU to turn it on again
PS
finally found it running the comparator on 2.8V LDO with a higher voltage from your voltage dividers at levels above the 2.8V did not work
running the Maxim 9022 with 2.8V reference from LDO and Vcc on battery supply works now
seems it can not compare higher voltages than its Vcc or close to it
So final results for the Tail and Aux boards are found
2S atm untested
Vbatt x R4 / R3 + R4 =Vref
When battery level drops below 3.30V, Light up Red.
3.255V x 360K/270K+360K = 1.86V
Calculate divider for LDO reference R8 360k fixed for one and 2S
1.86V=2.8V*R8/(R7+R8)
R7=0,531*2.8*R8-R8
R7=182k
on 1S is max 4.35V, the calculated reference voltage should stay below 2.5V for 2.8V LDO
4.2V x 360K/270K+360K = 2.485V
2S
is max 8.7V, the calculated reference voltage should stay below 2.5V for 2.8V LDO
8.7V x 390K/1M+390K = 2.44V
6,63V x 390K/1M+390K = 1.86V
Vbatt x R6 / R5 + R6 =Vref
When battery level drops below ~3.00V, Turn off all LEDs.
for 1S
3V x 360K/220K+360K = 1.86V
for 2S
5.88V x 390K/845K+390K = 1.86V
calculate like above just with another battery voltage 2.8-3V
The tail boards run with an 1kOhm resistor as bleeder this works with relative low current drawn from LEDs
Note the more current the LEDs draw the more voltage drops on the bleeder so battery voltage is higher than the calculated values
With standard hysteresis there is a fade between both LED groups and LVP shut down
this is PWM because when the comparator switches the LED off, then the voltage drop on the bleeder is gone,
so it switches on again just to notice that with the voltage drop again it is too low, aso
with battery voltage dropping the PWM cycle gets shorter and fades out
without a resistor like with new Aux boards it has a devent hysteresis
Nice work lexel!
1. If I put the board on my PSU and it is on I can connect it it is lightning up, reducing the voltage makes it go red and then turn off
But when I increase the voltage it does not turn on anymore or go from red to the other color.
I had the same problem & it turned out to be because of the high bleeder value I was using.
2. finally found it running the comparator on 2.8V LDO with a higher voltage from your voltage dividers at levels above the 2.8V did not work
The 9052 has a set Vref of 2.5V also a VCC of less than 2.5v will put the compactor to sleep, the 9039/9039 is set to 1.23V and the 9040/9043 is set to 2.048, which one are you using?
3. Vbatt x R4 / R3 + R4 =Vref
I’m surprised you having it trigger at 1.86V, this is where I lost you.
4. 1.86V=2.8V*R8/(R7+R8)
R7=0,531*2.8*R8-R8
R7=182k
Now I’m getting back on track again.
Whatever magic you did, I hope you’ll be releasing them for sale soon!!
