I will concur that those 60deg floody lens replacements on Simon's website (here) work well if you want to smooth out the default beam. I've got the new cyan and orange on order, will wait to see if I want to mod those as well.
I immediately threw in triple cu pill from kiriba-ru in there and then i immediately decided that it is way too heavy.
Then i went the other route. Stock pill and single Nichia 219C 2700k. It is far from the 3000 lumen output that the triple xpl setup could provide but at least it is more tolerable in terms of weight.
I also decided that the big Kiriba triple pill would be too heavy, so mine got a quad E21a 4000k R9080 setup with LD-A4 driver at 6 amps. Also added a two-channel lighted tailcap, warm-white/orange, to finish the look. Had a pretty bad donut hole so I wound up with DC Fix on the glass, its a bit floodier than I’d like and I’ll probably look for an optic or something instead, but overall I’m really happy with the build.
emarkd, thanks for posting those great pics! I’m planning to do an E21A quad for the S2+ also but wasn’t sure what optics would work but I’m surprised the stock reflector fits the quad emitters. Please post if you find better optics/reflector without the donut hole.
Btw, that lighted tail switch really goes well with the copper!
Thanks for the kind words all, I’m enjoying this build. At the same current the output seems comparable, but the E21a + DC Fix setup is much floodier so its kinda hard to judge. A triple behind either a 10507 or 10511 has much more candela for sure. Its also worth noting that 219b or c is capable of handling more current, so you can get a lot more output from those builds if you push them harder.
As for optics, I’ve already placed an order with Convoy for some of the single optics he stocks, just to experiment. I needed some other things anyway, so I’ll follow up in a couple of weeks when those arrive.
Personally, if I could choose a Convoy light in copper and get heavy anyway, it would not be the rather boring looking S2+ but it would be the S8 :sunglasses:
