I really like it. Right away tested some switches and leds and will be really nice for future projects that I have in mind. I got it from Banggood and it came in 11 days. I went on their chat help and asked if they would give me a coupon for this and they did and price dropped to $76.99 so I grabbed it.
Update: Voltage holds steady when in increments of 0.1V but when using 0.10V it swings about 0.15 and then settles between the 0.03 range after a short while.
I went to Home Depot today to buy some Top Soil. But the impulse shopper that I am, I bought this Dewalt bit set on sale… To be honest, I forget what I paid, but it was cheap!
The grit guard looks like it would work fantastic for letting Littleneck (steamer) clams purge sand before eating them. I have a metal grate, which works, but the whole salt water wanting to rust everything it gets near is rearing it’s ugly head. Usually rake clams and leave them to purge in saltwater for 2 days (I change the water daily).
Congrats raccoon! And please please please do yourself a favour and get The Last of Us! :partying_face:
Apart from the zombie apocalypse setting, I consider this the best game ever! :sunglasses:
trying pics once again with new post
If this dont work Google changed things since I last used photos. No other host setup at this time.
Got a 24 pack of LED tubes to swap out the florescent T12 in grage.
Got the 3000K ballast bypass, 18W per tube.
Pretty sweet IMO. Much brighter that the dual 40W tubes, warmer too.
Not done wiring and installing all the fixtures I have but 14 tubes used so far. 10 to go. Will also be splitting the circuit 50/50 or front and rear. Too hot lately to get up in the second floor. Big garage 25X50, second floor is 12X50.
This pic is lit with 6 tubes, one 2 tube fixture on the side and a 4 tube fixture in the middle with a diffuser lens
First pic the white balance corrected too much and the second looks more yellow than actual… Somewhere in between these 2 pics better describes the 3000K tint. Pretty pleasing to the eye and bright enough to work under. But the clear lens does make you see spots if you happen to look into the light. Why I used diffused fixtures directly over the work area.
Thanks for the confirmation. will delete the other post 386
Bus is a cheap and bad repaint. Looks like the paint mixer put a few too many drops of blue tint in the mix. Gave it a slight purple hue and the oxidization of the paint makes it look worse. Should be a deep darker red but not quite maroon. Everyone asks when are you gonna paint it. I cant because it would get messed up the first day. Its a truck to me. Just had a board fall into it the other week.scratched it but it dont matter. Garage has big 16ft and 14 ft doors ar each end. Had them both open and a good breeze came through and caught the board before I got back to get it. The drive through garage doors are pretty darn sweet especially in the direction of the wind. I need paper weights, chasing paper towels and plastic bags around outside gets old.
Better pic of what color the bus should be.Dash redone, old phone with broken cam…
