*BLF LT1 Lantern Project) (updated Nov,17,2020)
11696 posts / 0 new
sbslider
sbslider's picture
Last seen: 3 weeks 2 days ago
Zulumoose wrote:
How about no delay, make it like hitting the snooze button on the alarm, function being “wake me up gently” ramping up slowly from moonlight to full brightness over 5 to 10 minutes. If this were accessible with one button press after running sunset mode it might be a nice option.
Thumbs Up
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
DBSAR
DBSAR's picture
Last seen: 17 min 18 sec ago
update: 2-channel MCPCB designed. Here is the basic design of the 2-channel MCPCB for the lantern for the 3000K ~ 5000K ( or 2700K ~ 5000K LED emitters) to work for the tint ramping. After some tests, i found that having the different color temp LED pads in-line with each other linear from the center post/tube, created the smoothest tint mixing beam pattern. (*Red ring is the white center tube that covers the wires and the center bolt) two other black holes are for screws to mount the MCPCB to the lantern head.
(open to conversation.)
DavidEF
DavidEF's picture
Last seen: 13 hours 39 min ago
Looks good! Have you got this made in PCB design software or just a MSPaint rendering? Big Smile
- The YKK Philosophy
atbglenn
atbglenn's picture
Last seen: 2 years 2 months ago
I still don’t see my name in the list.
Boycott Nike
DBSAR
DBSAR's picture
just with photoshop after a couple drinks of rum Cool
DBSAR
DBSAR's picture
can add you as 893 if your not on the list, (sbslider can check on that as he has been updating the list)
atbglenn
atbglenn's picture
DBSAR, thanks! I definitely want one.
Boycott Nike
geetee03
Last seen: 1 month 1 week ago
Interested.
sbslider
sbslider's picture
sbslider wrote:
atbglenn wrote:
Interested
lantern interest list number 879 reserved for atbglenn
The list in the OP only gets updated periodically. I also maintain the “master” list which gets updated everytime I reply to an interest post. Sometimes it gets updated before I reply to an interest post. The master list has to ways to look at the data.
interest list sorted by entry number
interest list sorted by user names
You are definitely on the list, and if you can view the google doc links you can see it for yourself. If you can’t view the links, then you will just have to trust me until the OP gets updated.
geetee03 wrote:
Interested.
geetee03 has interest list number 893.
I will add the interest list sorted by user name at times has the last few entries on the end not sorted, as that is a manual step I do periodically. geetee03 is last on that list until I sort again.
KevinZA1988
KevinZA1988's picture
Last seen: 1 week 1 day ago
Awesome, glad I’m on the list! Thanks for clarifying.
Acebeam L18, Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Emisar D4, Fireflies E07, Jaxman E2L, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Olight Baton 3, Olight Warrior Mini, Olight M2R Pro Warrior.
Most of them have been modded! =)
https://photos.app.goo.gl/JaJaDv4V838AEJf39
Madtoffel
Last seen: 1 day 3 hours ago
Your MCPCB looks fine, I can’t find any reason why it shouldn’t work, but what are your final thoughts about the charging solution before we skip to the next topic?
And could toykeeper please make a short overview about the modes and funktions that are already implemented or planned before we talk about adding new ones? (Do we even have memory left ?)
sbslider
sbslider's picture
some information here
Unloco
Unloco's picture
Last seen: 1 day 2 hours ago
Interested.
ToyKeeper
ToyKeeper's picture
Last seen: 59 min 34 sec ago
http://budgetlightforum.com/node/56105
Plus tint ramping, probably on “click, click, hold” in almost any mode.
DBSAR
DBSAR's picture
Madtoffel wrote:
Your MCPCB looks fine, I can’t find any reason why it shouldn’t work, but what are your final thoughts about the charging solution before we skip to the next topic? And could toykeeper please make a short overview about the modes and funktions that are already implemented or planned before we talk about adding new ones? (Do we even have memory left ?)
The charging option is defintiely a planned part, but will have to leave that in more capable hands.
DBSAR
DBSAR's picture
I can’t see it in that diagram if “stepped” modes are an option instead of ramping, ( such as set mode groups as moonlight-low-medium-hight)
ToyKeeper
ToyKeeper's picture
Yes, the “stepped ramp” is a mode group, like moon-low-medium-high or whatever the user configures it to do.
The actual button presses involved are the same as the smooth ramp, so… click for on/off, hold to change brightness. But it uses a user-defined mode group. The result is very similar to an Olight Baton interface.
DBSAR
DBSAR's picture
Ah ok nice Smile
staticx57
Last seen: 1 week 23 hours ago
Common negative? I am surprised based upon how all of the other drivers are designed
DBSAR
DBSAR's picture
it can be split into two negative contacts if needed, i will leave that to the driver designers & programmers to determine.
Texas_Ace
Texas_Ace's picture
Last seen: 5 days 4 hours ago
This is how I would do it as well, it is less wires to run and they would go to the same place anyways.
staticx57
Right, and everything I learned so far with these things (which is still a looong way to go) is they are regulated on the negative side. I would have thought common positive.
DBSAR
DBSAR's picture
Thats what i was thinking too.
if its a negative side regulation, then its easy to flip the 2 positives with the negative & reverse the LEDs on the pads if negative-side controlling is easier.
ToyKeeper
ToyKeeper's picture
Yeah, it needs the +/- labels swapped so it’s common positive instead of common negative.
Generally BAT+ goes directly to LED+ with nothing in its way, while BAT- goes through fancy stuff on the driver before becoming two LED- connections.
The Astrolux S41 did it backward initially, and they had to change it. For a while they were putting LEDs on backward while they went through their old stock of backward MCPCBs, but that was still better than having the battery short directly to itself.
DBSAR
DBSAR's picture
good to know. Smile I will change the positive to Negatives then.
Caleb
Caleb's picture
Last seen: 1 day 4 hours ago
Wow! Super impressive work!
Thanks EVERYONE who is giving this amazing project life!
DBSAR
DBSAR's picture
Update: – new cross-section of the BLF LT lantern showing the design differences to the BLF Q8.
Texas_Ace
Texas_Ace's picture
Yes, you are correct, I figured they must be using a buck driver with V+ regulation or something. I just happened to get a notification yesterday for this thread and popped in. I know nothing about this project at all.
Flash-O-Maniac
Last seen: 2 months 1 day ago
Please add me to the list for one lantern. Thanks…
sbslider
sbslider's picture
I added Flash-O-Maniac at number 895 on the interest list.
