*BLF LT1 Lantern Project) (updated Nov,17,2020)
The charging option is defintiely a planned part, but will have to leave that in more capable hands.
I can’t see it in that diagram if “stepped” modes are an option instead of ramping, ( such as set mode groups as moonlight-low-medium-hight)
Yes, the “stepped ramp” is a mode group, like moon-low-medium-high or whatever the user configures it to do.
The actual button presses involved are the same as the smooth ramp, so… click for on/off, hold to change brightness. But it uses a user-defined mode group. The result is very similar to an Olight Baton interface.
Ah ok nice :slight_smile:
Common negative? I am surprised based upon how all of the other drivers are designed
it can be split into two negative contacts if needed, i will leave that to the driver designers & programmers to determine.
This is how I would do it as well, it is less wires to run and they would go to the same place anyways.
Right, and everything I learned so far with these things (which is still a looong way to go) is they are regulated on the negative side. I would have thought common positive.
Thats what i was thinking too.
if its a negative side regulation, then its easy to flip the 2 positives with the negative & reverse the LEDs on the pads if negative-side controlling is easier.
Yeah, it needs the +/- labels swapped so it’s common positive instead of common negative.
Generally BAT+ goes directly to LED+ with nothing in its way, while BAT- goes through fancy stuff on the driver before becoming two LED- connections.
The Astrolux S41 did it backward initially, and they had to change it. For a while they were putting LEDs on backward while they went through their old stock of backward MCPCBs, but that was still better than having the battery short directly to itself.
good to know. :slight_smile: I will change the positive to Negatives then.
Wow! Super impressive work!
Thanks EVERYONE who is giving this amazing project life!
Update:
  • new cross-section of the BLF LT lantern showing the design differences to the BLF Q8.
Yes, you are correct, I figured they must be using a buck driver with V+ regulation or something. I just happened to get a notification yesterday for this thread and popped in. I know nothing about this project at all.
Please add me to the list for one lantern. Thanks…
I added Flash-O-Maniac at number 895 on the interest list.
I did the two-part video tonight on the talk about the BLF lantern, will be uploading it to my youtube channel as soon as i get a good data connection!
What’s the name of your YouTube channel? Could you post a link to the video in the forum?
Yes please can we get your channel info?
I will post the link here tonight when the videos are up. :slight_smile:
