After careful considerations, I have decided to order the 2000 big springs first since they are the most popular, and I can validate their mechanical and electrical properties much more easily than with a small spring for good reason, and easier to prototype in a light.
Here are the final specs of the spring:
- Material: C17530 (Beryllium Copper) with IACS of 38%
- Spring upper diameter: 7mm
- Spring base diameter: 9mm
- Spring thickness: 1mm
- Spring height (free height): 12mm
- Plating: Electroplated zinc
Total number of coils: 6
The small springs will be ordered afterwards if the big springs are excellent.
I just want to make sure if everybody is okay with this, and is okay with the amount of springs they ordered
_
I am going with a 7mm top diameter because I have calculated that the yield strength is stronger with a 7mm top diameter rather than a 6mm top diameter because of the small bottom diameter of the spring, so there is a lower chance of plastic deformation occurring wider diameter.
If we are lucky, we should have have in 2-3 weeks, 4 if we are unlucky.
Edit: Another thing.
Would you mind if I make the spring 1-1.5mm taller? Just for all types of cells to be accounted for, and small plastic deformation with aging just in case.
I do think these springs have a lot of potential though.
With sufficient traction, maybe, just maybe, we can get them in other lights, like the BLF Q8 V1.5 I posted a thread about, a new special light from someone you really like, etc.
I have had issues with springs not being tall enough but rarely had a problem with it being too tall.
So an extra 1mm height sounds good to me.
I wounder if dropping the top size to 6mm might be a good idea as well, that way you could flip it upside down for drivers that have very small spring pads (like the TA 17mm).
