@teacher , thank you for the support again.
I’m going to be paying for the springs real soon.
If we are lucky, we should have have in 2-3 weeks, 4 if we are unlucky.
Edit: Another thing.
Would you mind if I make the spring 1-1.5mm taller? Just for all types of cells to be accounted for, and small plastic deformation with aging just in case.
contactcr
(contactcr)
July 7, 2018, 2:13am
217
Sounds good.
If i have learned one thing from this forum you should never give estimates when it comes to these things :+1:
+1
It’s always better to test them out.
I do think these springs have a lot of potential though.
With sufficient traction, maybe, just maybe, we can get them in other lights, like the BLF Q8 V1.5 I posted a thread about, a new special light from someone you really like, etc.
So, all in all, I hope this GB goes very well.
I hate to ask it again, but would you like a slightly taller spring by 1mm just in case it to make it fit all cells, including protected?
Thank you again, and again.
Texas_Ace
(Texas_Ace)
July 7, 2018, 2:58am
220
I have had issues with springs not being tall enough but rarely had a problem with it being too tall.
So an extra 1mm height sounds good to me.
I wounder if dropping the top size to 6mm might be a good idea as well, that way you could flip it upside down for drivers that have very small spring pads (like the TA 17mm).
Ok for the spring being 1mm taller. No cost difference.
Hmm? Why would you flip the spring? Wouldn’t that be the reason to use the small spring instead?
And wouldn’t the bottom 9mm diameter be too wide, and risk a short?
Texas_Ace
(Texas_Ace)
July 7, 2018, 3:21am
222
BlueSwordM:
True, I forgot about the small spring.
Okay then.
I’m going with the 7mm top diameter, and 9mm bottom diameter then.
Anyone against this for the springs?
I want to make the order quickly before sleeping.
teacher
(teacher)
July 7, 2018, 3:51am
224
BlueSwordM:
Okay then.
That size sounds good as does a bit taller.
Order those puppies……
Ok then.
I will place the payment with these final parameters:
- Material: C17530 (Beryllium Copper) with IACS of 38%
- Spring upper diameter: 7mm
- Spring base diameter: 9mm
- Spring thickness: 1mm
- Spring height (free height): 13mm
- Plating: Electroplated zinc
The payment has been sent.
Hope it goes well.
teacher
(teacher)
July 7, 2018, 4:15am
228
Excellent!! It probably will go fine……
But, should something go wrong at least you have PayPal on your side…. hopefully.
Now, the harder step will be Canadian customs.
But it should go well too. They’re only springs, and they didn’t react to an order of 350 Fasttech Springs, so it should go fine.
I’m going to be calling it a commercial sample, since technically, for springs, it is a small order :smiling_imp:
UPDATE 6
Payment sent, and order has been started. Let’s get this GB ball rolling.
1. 1mm wire BeCu C17530 38% IACS has been ordered.
50 big or 50 small?
Anyway, I will go to sleep.
See you tomorrow!
Caleb
(Caleb)
July 7, 2018, 5:31am
233
50 big AND 50 small
Thanks for making these available!!
maukka
(maukka)
July 7, 2018, 6:59am
234
10 small, 10 large springs, thanks!
MRsDNF
(MRsDNF)
July 7, 2018, 11:17am
235
Nice work BlueSwordM. :+1:
