Thanks, the temp sensor should be on the driver then, because the mcpcb only has power leads. I’m not a driver expert but I think it is integrated in the IC. Just wondering if there’s a way to isolate or deactivate the temp sensor, allowing it to run full power.
I got my dark green MT70 Plus today. What a beautiful looking light! A little disappointed when trying to put batteries in only to find that the battery tube was empty, no battery cage inside lol. Luckily my MF02 uses the same cage so did a quick wall test and I think I got lucky with the tint. No green or blue, just a solid wall of bright light. Need to try it tonight when I am back, but it sure is bright. If it's this bright in the daytime, I wonder how it's going to look tonight.
Even though it's a Mateminco brand, it must be identical to the MF04 Plus as the cage fits 100% and Mateminco makes the MF02 anyways. It seemed really bright but I was using the Protected Keeppower GA's. Going to try them tonight with the 30Q's and see if I notice any difference.
