I don’t have time to look them up right now, but I’ll try to remember where I saw them.
I think it was the 18650 from Imalent that did 15A which uses a 30Q.
Then the 20A was a 21700 5100mah from Acebeam.
Then I think there was a 26650 from Orbtronic that was 15A.
I think there were a few more and I know I wrote them in a thread, but I can’t remember where. I wish I could do a search for things I wrote across all the threads.
I’m not particularly into protected cells, but I’ll try and find the others later today if your interested.
That’s a good lead, I’ll see if I can find them based on that. I don’t use protected either but if there are some really good ones out there I wouldn’t mind having some for testing and sharing purposes. While I don’t normally have someone else using my lights it would be nice to be able to have a cell that could run em as they’re built to run and yet not be killed by someone getting over zealous.
You can , go to your account and then “my post” type in what you said or keywords under search comments and apply.
It only searches in your post and only the keywords you typed. :+1:
This was from the L6 thread. As always, just because a manufacturer says it’s battery can do 15A or 20A doesn’t necessarily make it true. I would do a search to see if they have been tested before I bought them.
