Samsung INR18650-15M 1500mAh (Cyan)
Official specifications:
Nominal capacity; 1500mAh
Minimum capacity: 1450mAh
Charging voltage: 4.2V +/-0.05V
Nominal voltage: 3.6V
Charging method: CC-CV with 100mA cut-off
Charging current: Standard: 0.75A, Rapid: 4A
Maximum discharge current: 23A
Discharge cut-off: 2.5V
Cycle life: 250 cycles to 60% at 23A discharge and 0.75A charge.
Operating temperature: Charge: 0°C ~ 50°C, discharge: –20°C ~ 75°C
Storage temperature: 1 month: –30°C ~ 60°C, 3 months: –30°C ~ 45°C, 1 year: –20°C ~ 25°C
This is a fairly old high current battery (Datasheet from 2010)
The discharge curves match very well and the capacity is just about constant at any discharge current below rating.
Conclusion
For its time an impressive tool cell, but the capacity is low by today’s standard.
Notes and links
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
Compare to 18650 and other batteries
