Of course.
The die itself can’t handle so much power.
Of course the Optisolis will be cooler.
It’s about 3W of max power vs 20W.
Of course.
Thermal resistance: Optisolis = 21-27 C/W vs 219C = 4,2 - 6,4 C/W.
Substrate: Optisolis = polymer based vs. 219C ceramic based
Optisolis might felt cooler outside but deep inside the die, it’s hotter than 219C (same wattage)
- Clemence
BAD news for you guys CCT mixer. Optisolis can’t be mixed in parallel configuration, the voltage between CW and WW is just too high. You can only mixed them in parallel within these two categories: (2700K, 3000K, 3500K, 4000K) and (5000K, 6500K).
The WW will suck up most of the current leaves the CW very dim. The reason is because WW uses 440nm pump and CW uses 420nm pump.
If you really have to mix those two groups you have to wire them in series or use current balancing driver (when multi strings present) or multi output driver.
- Clemence
Thats unfortunate. I still :heart_eyes: Optisolis though
Does anyone see an advantage of ww optisolii over e21a? I personally believe that below 5000k the difference in tint/cri is pretty much irrelevant
Optisolis:
- ultra high CRI
- Very cheap for its output & CRI
- VERY easy to solder
- doesn’t require special MCPCB (for “normal” applications)
The targeted applications are indeed geared towards general and luxury lighting such as those in museums, galleries, gem shops, printing labs, living space, etc…not flashlights
A good example is if we want to convert a gallery to very high CRI space. With E21, we would end up with very high cost with still less than perfect results. A diffused indirect lighting is required for lighting a space with minimal glare. A point source light source like E21 would lead to uncomfortable viewing experience. So, low to medium power LEDs are all it needs, distributed over larger area.
Even when spot lighting is needed, Optisolis paired with correct optic will do the job with much greater quality.
- Clemence
Yes, as lower an CCT and Illuminance that the less significant CRI. The main things is below of BBL. I do not tried optisolis but i do not seen difference between e21 r80/r9080 both 3000k
Clemence, this is a very comprehensive analysis, and I understand most of your points. I am just wondering if there exist an application that requires the extreme cri at 3000k?
At anything lower than 4000K I too don’t see much difference in colour reproduction EXCEPT for the redness. This means 2000K R70/80 is very yellow while 2000K R9080 is very orange. I don’t appreciate the high 90+ in warm CCT, only the higher wavelengths it brings. Until there’s a R7080 then R9080 is the only way to go to get such warmth from WW.
- Clemence
Late incoming shipment from Nichia arrived today:
This is a special E21A CCT I could not get. But surprisingly, this time Nichia has it. Based on my experience, 4500K in high CRI is not so easy to get from Nichia.
It’s D220, lower than I expected. But I see a pattern here. Brighter bin usually has higher voltage. For example earlier E21A sm403 D240 has M1 voltage bin. Voltage rank goes like this: L1 < L2 < M1
So D220 means its approximately as bright as the top bin D220 219B R9080 and lower than D240 219C R9050. It’s very good considering its domeless. Combined in quadtrix it should output approximately equal to the domed E900 144AM/AR.
- Clemence
And 500 pieces is a good stash too!!
I really like your photos
the E21A and Optisolis seem to have beautiful Red content.
I look forward to seeing some peoples mods with your new quad board and High CRI E21A and Optisolis. They have considerably higher R9 than 219C, which seem yellow to me.
So D220 means its approximately as bright as the top bin D220 219B R9080 and lower than D240 219C R9050. It’s very good considering its domeless. Combined in quadtrix it should output approximately equal to the domed E900 144AM/AR.- Clemence
I started to strongly think about a thrower build. I found a single cell (26650) Manta Ray C8.2 host, which is compatible with a 6V/3A boost driver, and is available with OP reflector. That host is originally intended for XHP50/50.2, but with a 6V configured VR21SP4, I think, it should work too (maybe I will need to grind the basement of the reflector to bring the focus closer to the MCPCB - but I hope, that will not be necessary).
Based on the 4×E21A measurements, which Texas_Ace made, the 6V/3A will be the exact sweet spot for this quadtrix.
If this will work for me, that will be super awesome… a 95 CRI ~1750 lumen pocketable thrower :sunglasses:
Ah… I just going to receive the current order from the local post, but I already thinking about the next Clemence order… I became an addict.
As requested by some member to post the CCT comparison tint shot of my Tiara E21A built. No 5000K, 5700K, and 6500K ordered by the time the picture was shot. FYI these Tiaras in the pictures below are all taken.
Sorry for the unexpected shipment delay. I had problem with the silicone thermal potting compound curing. I had to remove and clean all the potted Tiaras and start all over again :weary: . This time I made a special mixer to ensure they mixed well (and hardened completely)
Same picture defocused
- Clemence
Below is the test results of the Tiara Pro E21A. The base test used 6500K D240 bin. I don’t have the time to test all the CCTs one by one. But a fairly accurate calculation can be made using Nichia’s flux binning. Output for each CCT depends on the flux bin, adjust accordingly to get yours.
Actual measurement
Tiara Pro 4x E21A sm653 D240 R9080 [Yajiamei 60deg]
T2: 645 lumens
T1: 339 lumens
M3: 154 lumens
M2: 55 lumens
M1: 22 lumens
FF3: 3,58 lumens
FF2: 0,86 lumen
FF1: 0,03 lumens
Approximate output of other CCTs:
- 2000K D160 will have 160/240 = 66% the output of 6500K D240
- 2500K (D160 + D200)/2 = D180 will have 180/240 = 75% the output of 6500K D240
- 3000K D200 will have 200/240 = 83% the output of 6500K D240
- 3500K (D200 + D220)/2 = D210 will have 210/240 = 87,5% the output of 6500K D240
- 4000K D220 will have 220/240 = 92% the output of 6500K D240
- 4500K D220 will have 220/240 = 92% the output of 6500K D240
- 5000K D220 will have 220/240 = 92% the output of 6500K D240
- Clemence
Looks very good. Was it actively cooled?
Cooled in a glass jar filled with water. Start temp was ~25°C, ended at ~27°C
- Clemence
Actual measurement
T2: 645 lumens
T1: 339 lumens
M3: 154 lumens
M2: 55 lumens
M1: 22 lumens
FF3: 3,58 lumens
FF2: 0,86 lumen
FF1: 0,03 lumensApproximate output of other CCTs:
- 5700K (D220 + D240)/2 = D230 will have 230/240 = 96% the output of 6500K D240
- Clemence
D220 is 220-240 lm. So I think it would be good to use 230, not 220 like you calculate. Same with other bins.
I know but in this case being slightly pessimistic is better because of binning fluctuation between LEDs.
- Clemence
Interesting that the E21A’s characteristic is so different from the XPL and 219C using the same driver. Such a nice flat graph. Do you think the gradual lumen decline with the XPL and 219C is due to temperature regulation from the driver or just the way they behave?
