750mA per led is steep but my test shows that they can handle it, at least for a short while
I’m not going to use an Optisolis board but a 20mm XM-board, like I did with my S2+ with Optisolis.
Nichia vs XP-G3
If the response is good for AT40, i will get them to prep for AL1.
freeme, how much moddable is the light? Is there room to use a Carclo optic + lens above the MCPCB?
Also, is the driver: a) 20mm diameter and b) glued ?
BTW, what do you mean by “B finishing grade”?
Thank you in advance
Some measurements for references. Carclo Quad Optic is 24mm x 7.5mm from Hank's site.
My unit did come with minor dings. Some people may feel that this is "unacceptable" for modern manufacturing.
Thanks for the info. It may actually work with the 20mm 4x noctigon boards or the 21mm optisolis boards from clemence. Probably need a washer under the screw, but there will be a annular gap so might not be pretty.
Tried to order from link provided in PM, but Banggood says: “Under Restocking”. Why?
Interested
Yep… I was gonna order the 4 Nichia version but a pop-up said “No Stock”.
So I guess the answer is… none are in stock at the moment.
I asked to be put on the list in Post #138 - did not get a pm
Would like to buy one unit.
Thanks for your answer and photos freeme I guess this would be nice for a mod.
About those “dings” :person_facepalming: …I guess Amutorch is failing a bit in finishing lately Too bad because they have excellent anodizing and finishing in other lights. Is it possible that you got a sample and not a “final” model?
We gotta tell Shirkey about this so that they improve these aspects…
Thanks again!!
Cannot fit protected cell.
question-is possible to use protected? is it not too low output for 4 nichias? 1200 lumens?looks very nice this torch…
Thanks Freeme! Gave me a “preorder” option, good enough. I’ve paid more for less, this looks like a winner for the price!
Like the look and idea behind the cast aluminum head.
Fixed. [quote=g_damian] Tried to order from link provided in PM, but Banggood says: "Under Restocking". Why? :( [/quote]
Preordered the 4 Nichia version
Thanks freeme
Pre-ordered the nichia, pretty happy. Thanks.
Preordered. Thanks!
I placed my pre-order for one 4 x Nichia.
Thanks!
I got an email that mine is shipped.
I’m sorry about that, I was about the last to sign up and apparently the first to order, I guess they had just a few in stock.
