There’s more to the light quality than just the hotspot where the data is measured. It might look perfect on paper, but another sample could be better overall. So I don’t feel comfortable promising a golden sample which doesn’t turn out to be one. Certainly I’m not going to charge extra for those.
Yeah, some of them do look subjectively better than others which just goes to show there are big sample differences - part of why this thread came to be. However, ranking them in order from best to worst is counter-intuitive considering their purpose.
Duv doesn’t matter for these, but it means the distance the tint is from the black body radiator. Bigger number = more green/yellow. Lower (negative) number = pink/magenta.
Duv, R9, and TM-30-15 are the values I look at the most from Maukka’s test. Even more so than the CRI. I also look at Rg when the CRI is very high because I like to see saturated colors.
In general, I like to have 0 to –0.003 duv for neutral tint and –0.003 and below for warm tints for indoor use. But like Maukka said duv doesn’t really matter for these since we are not going to edc them.
teacher, I’m surprise you said you don’t know what duv is because you said earlier you would pay extra for 1107 which as a duv of –0.0001, which is approximately perfectly neutral or as close to the BBL as possible. If it wasnt the duv you were after, why did you prefer 1107?
YES!!! Maukka Thank you SOOOOOOOOO Much for doing this!!! Thank you also for making it a TWO color temperature kit!!! The variance between cool and neutral on my cheap meter seems significant!
I will take one of these kits for sure!!!
Plus if there is any chance you might consider measuring another light set for me I would be very interested. I would love to have a set that was tested at a higher output. Something that was stable at like 1000 lumens?
Indeed, I checked into having a company in the US measure some lights in a professional sphere. IIRC they wanted like $300 bucks per light, and that was if I sent them the light. So literally 10 times the money.
There’s usually no reason to measure high output lights for calibration other than having more significant digits in the number. Calibrating with a light measured at 2 lumens isn’t very accurate, especially if your tube close to 1:1 lux:lumen ratio, but 188.3 has plenty of resolution.
Lux meters are linear in their operating range and while some people are worried that their tubes read wrong on higher lumens, that shouldn’t be the case. Even if there’s leakage through the PVC, that will also be linear no matter the output. You just don’t notice it on lower outputs.
Ok, I will just start with the 2 then I would like to mention this on my Youtube channel if your up for making a few extra lights. This is really a big deal as far as I am concerned. If your ok with that I could use some help pronouncing your screen name….
