Has anyone else used this FET switch, they seem not to last more than 2 weeks before they stop working… for some reason the coin cell just craps out. ill Raise R1 value to 4-5kohms to slow down the charging current and see what happens.
The charging current should be fine. But maybe the discharge current stresses the cell too much. The maximum continuous discharge current is 0.1mA.
Try increasing R2, by a lot.
I thought about that as well… but the weird thing is that they just die on there own, the light would be sitting unused for a week with a fully charged 18650 in it, than the next thing I know when I try using it is its dead, the coin cell voltage is at 0. anyway I have some more boards on order, ill increase R2 like you said and see how that effects the battery and the FET gate.
I got a major problem here on my builds I can not firgure out
I removed hysteresis and adjustable reference, but it is still odd
If I put the board on my PSU and it is on I can connect it it is lightning up, reducing the voltage makes it go red and then turn off
But when I increase the voltage it does not turn on anymore or go from red to the other color
I measured the voltage on the ina+ and b+ and it is higher than the reference, but I got to disconnect the PSU to turn it on again
PS
finally found it running the comparator on 2.8V LDO with a higher voltage from your voltage dividers at levels above the 2.8V did not work
running the Maxim 9022 with 2.8V reference from LDO and Vcc on battery supply works now
seems it can not compare higher voltages than its Vcc or close to it
So final results for the Tail and Aux boards are found
2S atm untested
Vbatt x R4 / R3 + R4 =Vref
When battery level drops below 3.30V, Light up Red.
3.255V x 360K/270K+360K = 1.86V
Calculate divider for LDO reference R8 360k fixed for one and 2S
1.86V=2.8V*R8/(R7+R8)
R7=0,531*2.8*R8-R8
R7=182k
on 1S is max 4.35V, the calculated reference voltage should stay below 2.5V for 2.8V LDO
4.2V x 360K/270K+360K = 2.485V
2S
is max 8.7V, the calculated reference voltage should stay below 2.5V for 2.8V LDO
8.7V x 390K/1M+390K = 2.44V
6,63V x 390K/1M+390K = 1.86V
Vbatt x R6 / R5 + R6 =Vref
When battery level drops below ~3.00V, Turn off all LEDs.
for 1S
3V x 360K/220K+360K = 1.86V
for 2S
5.88V x 390K/845K+390K = 1.86V
calculate like above just with another battery voltage 2.8-3V
The tail boards run with an 1kOhm resistor as bleeder this works with relative low current drawn from LEDs
Note the more current the LEDs draw the more voltage drops on the bleeder so battery voltage is higher than the calculated values
With standard hysteresis there is a fade between both LED groups and LVP shut down
this is PWM because when the comparator switches the LED off, then the voltage drop on the bleeder is gone,
so it switches on again just to notice that with the voltage drop again it is too low, aso
with battery voltage dropping the PWM cycle gets shorter and fades out
without a resistor like with new Aux boards it has a devent hysteresis
1. If I put the board on my PSU and it is on I can connect it it is lightning up, reducing the voltage makes it go red and then turn off
But when I increase the voltage it does not turn on anymore or go from red to the other color.
I had the same problem & it turned out to be because of the high bleeder value I was using.
2. finally found it running the comparator on 2.8V LDO with a higher voltage from your voltage dividers at levels above the 2.8V did not work
The 9052 has a set Vref of 2.5V also a VCC of less than 2.5v will put the compactor to sleep, the 9039/9039 is set to 1.23V and the 9040/9043 is set to 2.048, which one are you using?
3. Vbatt x R4 / R3 + R4 =Vref
I’m surprised you having it trigger at 1.86V, this is where I lost you.
4. 1.86V=2.8V*R8/(R7+R8)
R7=0,531*2.8*R8-R8
R7=182k
Now I’m getting back on track again.
Whatever magic you did, I hope you’ll be releasing them for sale soon!!
The magic is use a Maxim 9022 which has no internal reference and only needs 2.8uA
The reference voltage is generated by a voltage divider off the LDO,
this is not so good when the LDO drops out of regulation at about 2.9V
(if you want the red burning quite down to a very low level as the reference voltage drops also, not sure what would happen)
positive is that the 9022 costs only 33% compared to the 9052
on the 9052 with a diode on vcc it could shut down at a higher voltage not draining the battery to the edge
with the 9052 you would need a 5V LDO for 2S lights, I am pretty much set at 2.8V for my lighted boards
you would run otherwise in the same probems like I had with higher compare voltages than the Vcc of the Maxim, as you cant run it on 8.4V
this would on the other hand give an option to run LEDs with less than 2.2V like green, red, orange and yellow as pair in series to cut current to half
especially on yellow and orange they get power hungry if you want them not dim
This is only lighted board I do not have a FET switch as local switch as the battery question is not solved,
yes basically having sort of button lithium rechargeable should work with a small coin cell if a diode is used to charge it
I asked the topic creator which battery and holder he is using but got no reply
Correct, the battery tabs just get soldered to pcb pads.
I tried everything with the FET switches including Lexel recommendation, the battery just dies in under 2 weeks.
Fady, you're right, you can change the resistor values to change the threshold voltages. Fady, are you also still having problems with the battery? It's fairly different to solder such a small package and you need to be very careful since too much heat can damage the cell. I've been using my lighted FET tailswitch in my main light for the past half year bringing it on many outdoor camping trips and it's been still working great.
Lexel, yes the MAX9052 is definitely suboptimal in quiescent current consumption of ~55uA typical. LEDs should draw on the order of ~200uA for 3 LEDs, so the comparator definitely is a large power hog. For your voltage regulator, you can use a better one I think, since there exists a lot of sub 1uA LDOs, and yes you can then use a much more jellybean comparator.
Thanks everyone for the support! When I have time I'll maybe do a quick update on the design.
