I had a xhp70.2 5700k sliced, and it turned a bit green. Which I donāt like at allā¦.
The xhp70.2 4000k dome on I like a lot though.
So when it comes to the choice between bad tint and great throw, or good tint and not so good throw I would choose good tint. But thatās just me.
I did find a light with a 90mm head and a sliced 70.2 led. The Acebeam K65. So it should have the same size reflector as our light will use. A 5000K NW version was tested by Maukka. Itās rated at 6200 lumen and 1014 meters throw. It actually did 4890 lumens and had 900 meters throw. Itās possible this discrepancy is due to the specs being for the 6000K CW version and this being the 5000k NW version.
Here is a beam shot.
He commented that the sliced dome gave the hot spot a slight greenish tint and it made the corona a stronger yellow. It also looks like the spill is fairly yellow. His full review is here. It seems to me like we would want the tint to be a bit cooler than normal since the 70.2 seems to appear warmer than you expect. Iāve got a 6500K in my L6 and it still looks a bit NW to me. I live with it though, as I canāt find anything cooler. This where we need a tint expert like Texas_Ace.
I think the K65 tests prove that with enough power and a sliced dome, over 1000m is easily achieved. I just donāt know if a sliced dome is worth it or not.
Leaving the dome on seems to produce a nicer beam with higher lumen output, but may only get us to around 900 meters. I think this is very reasonable seeing as the older L6 and S70s were only around 500m or so.
Is the world ready for a FET driver? That might be the only way to reach 6000+ lumen on a pair of 26650 batteries.
To start off Jason PMāed me so know that I know positively nothing about this light or thread besides what I scanned on this page.
Far as using the BLF name on the light, while there is no technical rules for using the name, I think that the BLF name should be reserved for lights that are ācompletelyā designed by BLF, using BLF firmware / drivers and to our standards.
My own personal standard for a āBLFā light is a light that I do not need or want to mod after I buy it.
Most lights made now days get input from BLF members in some form, so the line needs to be drawn someplace or BLF will loose itās meaning on a light.
That is just my opinion though.
Lights like the Q8, GT, FSW3 (SP? yeah, I am that far out of the loop) are good examples of this.
There is a massive variance in XHP70.2 tints, much more then the model numbers would seem to say in my experience.
Good tints are not easy to find as we are finding with the GT70.
I do not recommend slicing the production lights, all the XHP70.2ās I have sliced so far turn some level of green, although the very cool or very warm versions seem to hide this the best. It will also get warmer by 300-500k when sliced as well.
Could be it would turn out fineā¦ but it also could end up being a mess if not done properly.
Maybe it would be done properlyā¦ maybe not.
And this is assuming SOFIRN would even considering doing it in the first place.
āYears of trainingāā¦. I assume that was an overstatement. . But it would take some training & time is moneyā¦ which will add to the price.
The dedoming will add to the price also. Is everyone going to be OK with that for a āfeatureā they may not even want for this light?
Something I wonder, if dedoming is so quick & easy; why do people charge so much go do it?? Is there a high failure rate?? Beats me, IDK; but I do wonder.
The condensed version: Basically the same as a L6 or S70s. Single 70.2, pair of 26650. Side and tail switch. It may have a 90mm head instead of a 75mm. I hope SMO reflector. Driver and UI is not decided.
Sounds nice, although unless they use BLF firmware / driver and get a good tint LED, I know a lot of people would still want to mod it with said parts, so not sure I personally would qualify it as a āBLF Seriesā light, but that is just me.
So I guess it depends on what they end up going with in the end.
I donāt see any issue with using BLF in the name seeing as the light is being made for us by us its still a BLF build. As for the driver its better for them to make the driver its good inventive for them. For us its less time consuming and wonāt take as long to build the light and will keep cost down. Maybe we can use BLF firmware on there driver but the original modes already sound good.
Look at the Astrolux A01 that is a BLF edition light. In the end it doesnāt really matter but if we are going to have major input its a loss to not have our name on it.
The only time we have ever had an issue was after the first BLF A6 driver where made. We had companies trying to place BLF naming on random lights because they saw how big the group buy was.
Thanks @Sofirn for stepping up on this project, I think itāll be a big success for your company and for BLF consumers.
Also thanks @Sofirn for asking about using the BLF name.
Thanks @JasonWW too for the input. I agree that Sofirn SP70 sounds like a good name. Since I assume that the actual design and engineering will be handled in-house by Sofirn, they deserve the credit. Of course, if that changes, or if they decide to use a BLF driver, or if some BLF member(s) have a significant level of participation in the actual design/engineering, we can re-evaluate the name.
I would of course appreciate it if you mention somewhere in the final product description that it was developed with input from BLF members.
I would definitely prefer well hidden blinky modes. I frequently use strobe mode to discourage lurkers in a dark corner of my back yard. As for the UI, I think I would like:
That is the whole plan we build the light the way we want it. They will design the light to our specs giving us a choice of parts and design from our feedback in the thread.
I understand. So letās just hold off on deciding the final product name until we have the final specs nailed down. For now SP70 is good enough for internal discussion.
Iām surprised you donāt like the triple click for strobe. You can get to it faster and simpler. Maybe you think itās too easy to accidentally activate? If so, maybe it can be changed to 4 fast clicks. Then if you try to activate Turbo and press one extra time by mistake, it will just do nothing instead of surprising you with strobe.
One of the good things about my suggestion was that dbl clk is always turbo and nothing else. Also, a single click is always either on/off or back to the previous level. Nothing else.
Plus it seems natural to cycle through the blinky modes the same way you cycle through the brightness modes. This just makes sense to me.
Compared to existing lights of this style (L6 and S70), is it possible to design the head with thicker internal shelf and additional/larger fins for better heat dissipation?
The L6 shelf already looks to be about 6mm thick and can already handle 120 watts. How much thicker does it need to be?
In looking at the L6 cutaway, I can see that if there is a triple emitter version built later on, the shelf is going to be much higher. This would be a great opportunity to use the same basic outer fin design as the single emitter except cut the fins under the shelf much deeper into the head. You will have much more surface area then.
Both single and triple versions would look very similar until you hold them sideways and notice the different fin depths. Does that make sense? I might try and draw a picture tonight.
BTW, the SP70 will use a clear rubber side switch boot like the Q8 to make the switch leds easy to see in the dark and identify the color.
