New VirEnce MCPCB for E17/E21/119/144/233U
I borrowed your order for the pic and beam shots. I always test all soldered LED orders at 100% rated current for 1 minutes each.
- Clemence
Did you measure the lumens?
No, because I don’t have the right equipment to do so. You can use Texas_Ace measurement for comparison figure.
- Clemence
- Clemence
NOTE:
Actual stock Carclo 10622 beam was so much uglier with blue hot spot. While on the other hand the frosted 10622 (yes I frosted it myself) was so much better with no red band at all. My camera limited dynamic range can’t reproduce the actual looks.
- Clemence
Blu hotspot with optisolis? What is the cct on that and is the tint as red pink as E21A?
Blue-green hot spot to be exact. This Optisolis can only be used in medium to flood setup. TIR still very useful to direct the beam out front and make the transition smoother than no optic at all (mule). Tint is very neutral IMHO. My guess it’s not far from BBL. You’ll see Maukka’s test result soon, his sample already OTW.
- Clemence
So far, the Optisolis doesn’t seem as enticing compared to the E21A, but I’ll wait for Maukka’s test.
Indeed, Optisolis is not easy to implement in flashlight world unless very specialized optics used. In my opinion E21A still the best when very high CRI LED for flashlight is needed.
- Clemence
Clemence, could you explain what you mean here, please? What transition?
Without TIR optic as in mule setup (just flat lens) the beam would be full circle with hard cut-off. With most TIR optic you should get gradation with center weighted intensity.
Any optics should help to throw the beam outside the flashlight rather than just absorbed in the cavity as heat. Let’s say we can get the same beam profile with mule and TIR optic (super even and floody). There must be a difference with output, because the TIR optic will direct the beam off the front more than a simple flat lens. This is especially true if the LED shelf cavity is deep and non reflective (black, matte, etc…)
Note: Frosting/diffusing any TIR optics should be done after the collimation (top surface only), except for some severe cases. Because frosting the LED cavity in the TIR optic would upset the designed geometry and lessen the chance to move the light to the front. Most TIR optics designed with uniform lambertian light distribution from the LED die.
- Clemence
I assume that he means to say that with an optic, even if heavily frosted, you do get an actual beam which is bright in the middle with the brightness slowly fading away to the side, while without optic you do not have a visible beam at all, just flood light from front to side (although right in front of the led the brightness is higher than at the side)
Edit: clemence beat me to this answer, and said it better :slight_smile:
+1 Jos, and a mule’s outside perimeter beam shape will also follow the bezel’s shape (shadowing).
- Clemence
I see what you mean. I really appreciate your yhorough explanations. They always add some extra bits of important and useful info in addition to what was asked
Yesterday received order No. 10244
Today I decided to mount the VR16SP4 with the Nichia E21A 3v Configuraton in Skilhunt H03.
He soldered everything as it should, as recommended by the seller.
I decided to check Fluke. No diode burns.
Very sad …
What do you mean? I’m confused here
To check the diodes, put the multimeter in the diodes check mode
Diodes do not light, an audible signal is heard
The driver did not connect, I decided to start to ask
What’s what and why
Your module tested at 8A for 1 minute without problem. Try to disconnect it from the driver and test again. Smaller solder pads are the anode.
- Clemence
Everything was done, as in this photo, there is no result. The diodes are dead. Do not understand why. Can the diodes partially break off during soldering and move away from the pads?
https://i.imgur.com/tpiNOQy.jpg
Yes, it’s possible if you solder them for to long with weak soldering iron. The heat will melt the entire solder on the MCPCB and possibly one or more LED shorted (if moved). Easy fix is to add flux in between the LED gaps and reflow the whole MCPCB on a hot plate. Remove all wires and test again. Don’t forget to clean it THOROUGHLY before testing.
- Clemence
