HKJ
(HKJ)
July 13, 2018, 3:41pm
1
Varta LongLife C 4114
Official specifications:
Shelf life: 10 years
Nominal voltage: 1.5 volt
Typical capacity 7600mA (Discharge with high resistance)
Permissible temperature range: –10°C ~ 50°C
Chemistry: Alkaline
This is a standard Alkaline C cell from Varta.
This is typically Alkaline discharge curves that are very depend on current.
Conclusion
Performance looks to be
about the same as the other Alkaline C I have tested.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
Compare to other C/D batteries: Alkaline/NiMH/Lithium
HKJ
(HKJ)
2
I have added a C/D battery comparator.
Thanks for the review HKJ I never knew c size cells hold so much energy.
HKJ
(HKJ)
July 13, 2018, 5:45pm
4
Like all Alkaline you have to be very gentle to get all the energy, high power loads is very bad, there you need NiMH batteries.
Pete7874
(Pete7874)
July 14, 2018, 2:48am
5
Yeah, seriously. At 2A of current, an AA Eneloop has more capacity than this C cell.
I guess that is why it was so common to use multiple c/d cells in equipment back in the days. We still have a National Panasonic radio from the 80s that used like 8D cells i think. Even the old Maglites are the same. Can’t imagine powering the thing with cost of batteries back then.
