Guys I have great news. So my ZY1276 just came in the mail. After trying it. I was so confused of the firmware version. Its already on 3.36D . And it appears that I have the new ZY1276P version (I know cuz when it shows the model number when you holding button bfore going to configuration mode) okay. So basically. I should be able to check emarker without PD adapter. No documentation yet. So idk. I’m waiting for my type c cables. Also. I’ve found a closed beta firmware . 3.36E (newer than stable) it removed some Chinese text. And vooc check . For beta testing QC to PD 2!! (He said the memory isn’t enough for new features so he needs to remove some to get some) . Haven’t tried it yet tho. He said something too about not using it with emarked type c cable. Anyway here’s the fw if you wanna test it. ZY1276 only!! I’ve flashed it successfully.
You’re right, i meant the voltage setting in the STM32 programmer software.
I do have the pogo pins, but can’t connect the ZY1273 to flash the firmware 3.1 on it.
but YZX meter did not have ,
For UM34C, it support USB 3.0 and Quick charge recognition mode:QC2.0、QC3.0、APPLE 2.4A/2.1A/ 1A/0.5A、Android DCP、SAMSUNG, support support OPPO phone VOOC, OnePlus DASH
Though UM34C and UM25C have Type-c port , but there is not trigger, only support type-c charge, not recognition
although for data or some function, it is not better than YZX meter, but for the price , it is already best …
for USB load, there are many choice , LD25/LD35
If someone need more cheaper meter, but colorful display, there is also choice AT34
That makes sense I suppose. It would allow you to continue a test later or go straight on to a fresh test and record previous data at a later time. I thought it might have been something more significant I was missing.
I have just bought a ZY1276 from Amazon which appears to have recent firmware. I tried AutoDetect on a new Samsung Galaxy S9 charger expecting the Samsung-AFC 9V protocol go green, but it indicates as red which is not available. It is a genuine Samsung charger and has 9V indicated on it. Has anyone else come across this.
