4-5000 lumens high is too much I think. MF02 has much more head mass. And the jump from that to 6-7000 is not significant. 3000-3500 lumens ramp max can run until battery dies with slight warming up.
OMG this is so important especially for a sustainable high output light like this! :+1: I don’t want a 7000lumen light that loses 2,000 lumens in 1 minutes
lol, I am aware but for some reason the china manufactures love to make the walls that thin unless we specifically tell them to make them thicker.
Basically they should leave as much material as possible inside the head, there is really no reason to remove it, the slight weight savings is not worth it IMHO.
It already stated as a 2 cell version. a 2/3 cell driver will raise the driver cost. If somebody need more runtime carry 2 extra battery and problem solved with even more runtime than 3 battery.
I didn’t changed my mind. that 4000 lumens I mentioned about my MF02 setted up but it is not a huge jump from there to 9000. So anything between 2500 and 4000 for high mode I will be happy. If in ramping they cannot make separate turbo it is also OK but it need thermal regulation.
I know Narsil is not on option sorry for mentioning it again.
I don’t really know what Sofirn is able to program for thermal control. Their newer SP32A v2.0 is a FET driver and is labeled as having Advanced Temperature Regulation (ATR). The C8F is also a pocket rocket. Can someone comment on how it’s thermal protection works? Does it keep the light at safe temperatures, etc…?
The XHP70 is available in some nice tints at 90 CRI, e.g. the XHP70A-01-0000-0D0UJ445G I have in my Acebeam L30. I’d really like to see options like that rather than just focusing on power. There are plenty of lights on the market that have huge output, but not so many that produce really nice light, especially with higher output.
Looks much better. Is this one gonna be a single emitter or a triple??
Never mind that question… I found the answer in post #1. Single emitter first then possibly triple later. :+1:
Much better, I might make the bottom fin on the right side slightly less deep to improve heat transfer up the head but that is about all that could be done except closer tolerances to the reflector.
Going backwards to the older xhp70 (instead of the 70.2) would necessitate using an OP reflector to minimize the donut hole which means you loose a lot of throw. I don’t think we should go in that direction.
