Not really sure if this is a good deal or not but thought I would post it. Looks like a stout little light. Figured I would grab one and turn ya’ll on to it if you need another AA pocket rocket. No blinky modes, just low, med, and high with a XP-L. Which I am assuming is CW.
Well, the listing talks a good talk. DTP copper, no pwm, handles 14500, etc. Sounds like a nice deal.
I like the styling. Nice to see lights with lots of knurling. :sunglasses:
very similar to Lumintop tool AA, except for some of the body
No pwm is for sure a plus for those that are sensitive to it. I like the simplicity of it. No crazy blinky modes is always a winner in my book. Figured for less than $12 I can gift it away to someone who doesn’t know any better if I don’t like it.
thats cool, I guess its made in similar factory to tool, tail area and diffuser are identical, but tool pwm is pretty bad, might check it out
Agreed, I normally don’t see well implemented pwm, but I do see it just a bit in the Tool. Not enough to drive me crazy but enough none the less. My A1 will be here Monday, I can give you the scoop on it before you order it if you want.
Similar to Sofirn SF14, no?
If the light in reality is as the listing describes it seems like the perfect aa/14500 edc.
cool, the clip is also identical, pretty weak on the tool, will wait for your report, good price tho. From having/using the tool for about 5 months that’s the first thing I thought of, tail, clip and diffuser are the same, not sure about the sofirn, these may all be coming from same factory with 3 different lathes doing the knurling, not saying its a bad thing, I use the tool a lot cause of the diffuser, makes a great nightlight, this one may be a home run at that price.
The Sofirn sf14 clip is excellent. I edc it on the outside of my Leatherman pouch, holding on just by the clip, it is the best clip I have used.
Tempting for the price. I’m curious as to how it does with an Eneloop.
Light Modes
The default mode is LOW when you just turn on the flashlight, No Memory Function.
When use a 14500 battery, the brightness can be Low(20LM) - Medium(280LM) - High(600LM);
When powered by AA battery, the mini light gives out Low(1LM) - Medium(30LM) - High(220LM)
How to Use UltraTac A1 Mini Flashlight?
Unscrew the flashlight head or tail-cap;
Insert the battery with the positive side towards the head;
Reassemble;
Click the tailcap switch to turn on / off the light;
Press the switch when light on to switch mode between Low, Medium, High.
Pasted from Amazon.
How can the UltraTac A1 circuitry work such that the AA schedule is:
Low = 0.5%, Med = 14%, and High = 100%, but the 14500 schedule is:
Low = 3%, Med = 47%, and High = 100%? (rounded to nearest whole percent)
Just a newby question. Thanks.
No clue. I am assuming the driver characteristics increase output with the increased voltage. Current draw with a LiIon cell would also make for more output I am assuming as well. I am by no means a electrical engineer so I am just using the simplest answer that my simple little brain can manage.
This Charles BridgTec review provides a 10% discount code SS6TRV2E for the UltraTec A1 on Amazon. So, I cancelled my original Amazon order and repurchased one for $10.75. With Prime, it will arrive Tuesday.
Nice!!!
I also ordered one with the discount code. I had wanted a Nitefox K3, and a Tacteagle E09. With the discount and Amazon Card cashback cost was $14.68.
Jerry
Looks like the price has gone up by a buck. May still be worth it. Is it any better than utorch ut01?
Wow, they can go to Hell now.
Was 12bux, limit 2, now 13bux and limit 1. Was just scrounging for something else to pad out to 25bux, and now this.
Wellp, they just lost my orders…
The Sofirn SF14 would be my first choice as an alternative to UntraTac 1A because the two are functionally similar, and the Sorfirn SF14 is a good value. The Lumintop Tool AA is another contender, but the SF14 is less expensive. You can purchase a SF14 from the Official Sofirn Store on AliExpress for $11.90 right now, and I've seen it on sale cheaper. You can sometimes find the Tool AA on sale for around $16.
The table below provides an output comparison of the three flashlights:
Flashlight | Battery | Lumens | ||
Low | Med | Med | ||
UltraTac A1 | 14500 | 20 | 280 | 600 |
AA | 1 | 30 | 220 | |
Lumintop Tool AA | 14500 | 8 | 95 | 550 |
AA | 7 | 25 | 110 | |
Sofirn SF14 | 14500 | 5 | 110 | 600 |
AA | 3 | 33 | 230 |
All three flashlights have
- A tail switch
- Three modes: Low -> Med-> High
- No mode memory. They always start out on Low.
- No Strobe mode
- Solid aluminum construction with an IPx8 rating.
The utorch ut01 is really not my type of flashlight (because it had a side switch and mode memory), so I'm not a good person to give you any advise about it.
