Will battery life be reduced?
NOT sure if this is the right place for this.
Would this be the same concept as charging a 16340 @ 1 or 2 amps?
My friend gave me a car charger for my LG K20V Phone. I noticed the specs are different than the charger LG provides.
Here are the specs.
My Battery:
BL-46G1F- 3.85V-2800mah/10.8Wh
LG Charger:
5.0V=0.85A
Car charger:
INPUT=DC 12-24V
OUTPUT: 5V=3.1A Total
[Each 2.4A Max]
I am NOT sure what Each 2.4A means??
Seems to charge from Two to Three times faster.Car chargers AMP output is at least 3X times higher.
Verizon said it will be fine but I know people on here know more than they do!
Would this Car charger REDUCE the life of my battery?
,Thanks
It shouldn’t.
The charger part is inside the phone and should be regulating the charging process.
It’s a matter of demand and supply. You car charger can supply enough but your phone will only ask what it wants or needs.
Your car charger can output a total of 15.5 Watt, 5V x 3.1A.
While using just 1 output the maximum current is only 2.4A or 12 Watt.
If you’re using the 2 outputs the maximum output will be the full 15.5 Watt divided by the 2 outputs.
It should mot. The phone will limit itself to the max charge it can support.
Charging a 10Wh cell at 10W in this case is not bad.
In most cases, when you are below 1C fast charging, what matters the most is the SOC during the use of the phone.
Not charging above 90% and not letting it discharge below 20% will help with the battery’s cycle life tremendously.
I personally use a root app to limit charging to 87%, but you can do it manually if you want.
I’m wondering if that’s true.
Not the battery improvement part but that you should only charge it till 90%?
Isnt that already configured inside the charging algorithm of the phone?
Just wondering btw.
Ok,thanks.
I know the car charger charges about Twice as fast. That was my concern, that charging Twice as fast would not be good for the battery? As long as it won’t shorten the batteries life, that is all that matters.I got the Phone/battery on August 19,2017,almost 1 year old.
It was also suggested to me to NOT charge the phone to 100% . Their first recommendations was to charge 80-discharge to 30. Also told me that 90% and 40% would lengthen the life of the battery. that is what I do. Most times I charge it when its b/w 40% and 50%
Wolfdog,
you should get 500 cycles out of a liion battery. That means daily charging after two years you have a weak battery.
The 40 to 90% charging extend the life
this article may help
There is a paragraph about satellites
For occasional-use flashlights, I charge to about 4.1v. That gives me a 90% charge, and probably doubles the life of the battery. I charge to a full 4.2v if I know I will be using the light soon, and for a long period of time. Leaving cells sitting around at full charge isn’t the best practice if you want your batteries to last a long time. 4.1v is a lot easier on them. You could go lower, but at some point you have to trade off capacity and battery life. IMO, 4.1v is a good trade-off.
Just wondering btw.
[/quote]
That’s what I’m wondering too.
When you phone says 0% it’s a bit above that. Not sure about 100%
I charged up an older phone to 100, then removed the battery and tested it on my DMM. It measured 4.20v. So, at least on some phones, 100 charge means a full 4.2v charge on the internal battery.
It makes sense, too. The phone manufacturers don’t care if the battery lasts 2 years or 5 years. They want you to buy a new phone every 2 years, whether you need it or not. If the battery is dying after 2 years, all the better for the phone manufacturers, since that will incentivize people to just buy a new phone (or fork over a rip-off price for a new battery).
Where do you hook up the leads?!!! I tried awhile back and must have done it wrong!
I got it! I was not patient enough[ and had wrong contact] when I tried it a year ago.
Mine was 78% charged and the voltage was 4.05V.
You have me curious now. I am charging it to 100%[a rarity] to see what the voltage is.
So I got 78% charge =4.05V
100% Charge = 4.31V…
When I saw 78% = 4.05V I knew it would be a higher reading for 100%.
I am going to test it at 90%,Probably pretty close to 4.20V.
EDIT: Here are my numbers. I love numbers. every battery has a charge cycle list, all my torches are in a rotating chart,on and on!
100%= 4.31V**904.17V*78=4.05V
I Think I figured it out. My 18650/26650 ect. Lion battery cells are 3.7V [Nominal]. This cell phone battery is 3.85V [nominal].
Hence the 4.31V at full charge instead of 4.20V. :+1:
That’s fine if it’s a lithium-ion cell designed to be charged to 4.3v. Otherwise, they’re really over-charging it just to squeeze out a bit more capacity, and that’s going to affect the life of that battery.
My guess is that it is. Being 3.85V nominal instead of 3.70V nominal.
It has worked well for a year with no signs of degradation,the 90/40 charge/discharge probably helps.
Ah, yes, you’re very likely correct.
I could be totally wrong but I am just using logic. If the nominal voltages go up,I am thinking the maximum voltage goes up.
I am sure someone on here knows the answer to that. I have basic knowledge for 16340,14500,18560 ect. Li. Ion rechargeables , not really familiar with these phone batteries that have different nominal voltages.
Where is Professor Gauss when we need him!! lol!!!
Certainly you aren’t totally wrong.
It’s about a certain margin. It’s no law that margin changes with the voltage in a linear way.
With new tech the margins could change along with voltage.
