Emisar D4S review
Very promising indeed. I’m in for one for sure.
The ~20 years runtime on aux LEDs (low) is already the dealbreaker for me…
Is there really a new version of the DQG avaible? I have only seen V3 up to now.
I also consider the D4s too big compared to the DQG, and would have preferred a 7 LED variant. Now I have to use the DQG for my planned RGBA + 3x white build - which is way more difficult due to the serial LED setup and the driver design.
It’s probably worth noting that the li-ion cell’s self-discharge rate is faster than that, so it probably won’t actually last 20 years per charge. But if the driver and LEDs were the only source of drain, it looks like it should last a couple decades based on how low the power draw is.
Effectively, there is no difference in terms of battery life between the low aux LED mode and off.
Yeah, same here. 1x26650 is simply too big for me to carry around all the time. Otherwise it’s a nice light though.
Not every flashlight has to be “edc”-small. This looks like a fantastic light for a backpack/bag, car, maybe even jacket pocket carry for an outdoor event. I’m into it.
it is possible if I have the measurements of the Noctigon boadrs
I made very similar in this build
sanded down 0.8 to 0.2mm
thermally glued not needed on aux LEDs
0402 and 0603
with balance resistors and LDO so each LED could be another color and constant brightness over whole battery voltage
Perfect, now I want some orange aux LEDs on my D4 :person_facepalming:
I have a D4 MCPCB at home. I will measure it just tell me what dimensions you need. In D4 the screw holds the MCPCB and two legs of the optics resting on the screw. So if we make like D4S and same screw holding down the aux pcb you need to cut off more from the legs on screws. Maybe you need use longer screws also.
Edit: I think less leds are also enough. like 6 or 8.
Ummmmm… Yes, please!
looks great, a green would be nice to my green 18650. I hope price will be around 50$ or so but who knows…
Holey moley!
Just because you can draw something doesn’t necessarily mean it can be made.
Try snapping that one out of a biscuit. Nevermind routing out all the big holes.
I’d love me one of those boards to pimp my D4 :party:
I am in contact with Intl-outdoor so they should become availiable fully assembled from him
Cool.
Cool!
But I would like to choose my own leds of course, so I would not mind an upload on Oshpark too (or don’t they do such thin boards?)
Oshpark 2Oz are 0.8mm thin, this should be enough
on chineese fab on panel I would go to 0.6mm
also made a programming adapter for my future drivers
same order in 2 Oz!
Fits those pogo pins from banggood
A part of me wants to call it overkill, but that aux LED board with its own regulator and balance resistors sounds sweet.
Lexel, can you clarify, which one is expected to become available assembled from intl-outdoor?
Thanks, :sunglasses: , ordered!
has not been decided yet
The resistors and the LDO costs in serial production less than 20 cents so why not stick it on it
Of course a sort of LVP like I am planning on my tail boards would be possible as well, but that costs like 0.6$ more
Way to go!
But pogo pins do need some support, they are long, thin and bendy. Which is why I suggested a 3D printed support.
Perhaps a big dollop of hot glue might suffice.
Back in the day my kit was designed for ATE on a GenRad/Teradyne bed of nails, with guided probe for detailed stuff. Everything made extremely precisely and solidly.
Not necessary for a torch. Just a common flashing interface.
