rainbow lighted tail boards any color combinations possible, adjustable with 2 trimmers
31 posts / 0 new
Lexel
Lexel's picture
Hi,
First I tried it on my regular 6x Tail boards with conventional 6 Balance resistors and a 1kOhm Bleeder
Main Problem was that with low battery voltage the higher voltage LEds (Blue, White, pink, ice blue) get dimmer tan the low voltage ones (red, yellow, green)
I came up to enhance this idea with a voltage regulator, but had to do some steps to make it work
first get the voltage and resistor value for each LED at the same brightness
Then I made some calculation to get fixed current draw versions
It is also possible to use this with side switch lights like Convoy L6, as I can get the parasitic drain for the 18kOhm bleeder down to 0.4mA when the tail board has 0.15mA for the LEDs
Now the first 4 Prototypes
I did quite some measurements and tests to even out the brighteness of them
Firt L6/L2 prototypes are build and successfully tested on my bench, modding the lights will follow
One tme i skipped the very current hungry Emerald green for a warm white
The tail board itself uses a voltage regulator so the brightness is constant down to 3V cell voltage and can be fitted with 1S or 2S voltage regulator
The 2S Voltage regulator has a 0.1mA higher drain
I haver also ordered fitting 3×3mm trimmers so that the brightness of the board can be adjusted for 2V and 2.5V LEds in 2 groups
On the other hand I can also build em with a current draw from 0.15-1mA with the balance resistors without trimmers
The rainbow LED boards have one drawback which are the inefficient Emerald green and yellow LEDs,
so their brightness is lower than green or white LEDs at the same current
Sale in this topic
http://budgetlightforum.com/node/61671
Edited by: Lexel on 08/15/2018 - 11:04
patmurris
patmurris's picture
Last seen: 6 days 3 hours ago
Really nice! Thumbs Up
Now trying to figure where i could use one…
Mstevens113
Mstevens113's picture
I have an L6, would be interested to know how to go about fitting one of these.
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 day 12 hours ago
Love
Nice
Lexel
Lexel's picture
they replace the washer in the tail, you need from Convoy a set of transparent switch covers
Simon sends them for a small compensation to you if you message him on Aliexpress
Any color combination you want is possible
I have also a 4 LED side switch version for the L6
netprince
Last seen: 6 min 46 sec ago
I’m interested in two or three depending on price.
Lexel
Lexel's picture
first test in Convoy L2
djozz
djozz's picture
Last seen: 7 hours 31 min ago
That looks really good Lexel!
polarweis
polarweis's picture
Looks great. Does it stay on all the time?
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
Lexel
Lexel's picture
as all Clicky Tail cap lights it goes out when you turn the switch on
Turby3Pots
Turby3Pots's picture
yeah if it turns off when you hit the rear clicky on an L6 then I’m in for at least 3.
Lexel
Lexel's picture
I also have 4 LED boards for side switch on the L6, so always one switch is lit
L6 as e-switch light has limited current on the tail one as the bleeder resistor needs to to be pretty high (0.15-0.3mA)
Ill get in next days a L6 to mod then I can test the driver, the L2 driver has an odd behavior that you do not need a bleeder as the driver bleeds already to an LED Tail board
saypat
saypat's picture
Last seen: 8 hours 2 min ago
fabulistic!!!
NeutralFan
NeutralFan's picture
Last seen: 2 days 17 min ago
Looks very nice Lexel! I have a hard enough time matching same color LEDs and experimenting with resistor values in my lighted tailcaps, let alone the complexity of what you have done. I admire your ingenuity. Thumbs Up
I’d rather use my flashlight around the house than turn on the lights.
Lexel
Lexel's picture
I did today more testing with my Convoy L6 drivers and illuminated tail caps
Final result is that with the parts I use on the driver I can feed up to 1mA to the tail cap without using a bleeder resistor, so there is no standby drain from a bleeder at all when the light is switched on over the tail switch
This is likely due to the voltage regulator I use that is so friendly and bleeds for me to the tail cap
klrman
klrman's picture
Does the stock driver work with the lighted tail cap?  I'd also be very interested.
Lexel
Lexel's picture
Tested this with stock driver it does the same
klrman
klrman's picture
Very interested then. One color like purple is fine for me and maybe another one blue.
Edit:  Maybe I misunderstood, but if the rainbow ones light up equally bright, then I would prefer those over one color for sure.
Gunga
Gunga's picture
Last seen: 4 hours 37 min ago
Very interesting!
Lexel
Lexel's picture
The rainbow board is designed to light up equally bright even with the cell voltage dropping down to about 3-3.4V depending on brightness and Bleeder resistor values
Lexel
Lexel's picture
On 2S lights I discovered an interesting behavior that makes side and tail switch glowing on my 3 Channel 2S TA drivers in an L6 for example
shirnask
shirnask's picture
Last seen: 2 hours 36 min ago
Interested
klrman
klrman's picture
Very interested then for a few of them.
bmengineer
bmengineer's picture
Last seen: 5 months 4 weeks ago
I’d be very interested in a lot tailcap for my Astrolux S1 if I could find one that would play nicely with the driver.
Find all my reviews of flashlights and more gear at www.bmengineer.com
Muto
Last seen: 10 min 56 sec ago
Interested
The difference between Hoarding and Collecting is the illusion of Organization
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
DavidEF
DavidEF's picture
Last seen: 1 day 3 hours ago
Bump? Innocent
- The YKK Philosophy
vinte77
Last seen: 5 months 2 days ago
I’d be interested in a couple but with a different color scheme than rainbow.
808Hi
Last seen: 6 days 13 hours ago
Interested in a couple rainbow color scheme
Lexel
Lexel's picture
Yes I know its late but I am super busy with some big projects with flashlight companies as well with the usual driver orders
2. generation with bugfix I got to here ready to be build, just need to work to make a proper sales topic
3. Generation with LVP and low battery warning I got the boards now here but unfortunately the ICs are backordered to 27. June
this LVP needs also some testing before I can hopefully sell v1 of the boards or may need to make a bugfixed board
Please PM me with what you want
clemence
clemence's picture
Last seen: 10 months 1 week ago
If you’re interested in colored E17A….but limited to only white (CW/WW), red, green, blue, and amber. The advantage is all of them have same forward voltage. Should be interesting for TIR accent light because they can be driven (officially) up to 1000mA (700mA for the Green). Green (NCSGE17ATE) is extremely bright. Some samples already on their way to Djozz.
- Clemence
Lexel
Lexel's picture
- Clemence
difference in forward voltage is solved with a 2.8V LDO
There is no goal to have a powerful secondary color it is to have a devorative low glow like with tritium vials, but even low currents like 0.2mA total blast every tritium away like hell,
to got with RGBW lights best solution is to cut traces on MCPCB and connect each LED on its own
