$10
Last time I had them was more than a year ago. Dont remember weight. Defenetly under 50gr.
The P60 single led is it with a retaining ring or do you solder the driver ?
No retaining ring, solder or press fit.
Thank you for the fast reply
kiriba-ru
I’m interested in a maglite D kit with the adapter for a 17mm driver, shipped to the US. Is this still available and if so what would the total cost be, thanks.
All parts listed in the first post are available.
$13 kit
$4 17mm adapter (extra $3 if you want thin custom retaining ring instead of regular convoy one)
$8 shipping cost
i will be using a QLITE driver so which adapter would you recommend ? Thank you for the quick reply.
I recommend custom rings if you will use driver with components on both sides.
just so i’m clear, for $3.00 i get a retaining ring that will hold the 17mm driver in the adapter, is that correct ?
Yes. Custom ring is not cheap.
$3.00 for a custom machined brass ring sounds reasonable to me, certainly better than soldering one in
C8 copper pill with threads measure like fasttech brass pill are available?
Not available and never will be.
You can use this one: http://kaidomain.com/DIY-26mm-D-x-13_5mm-H-Copper-Driver-Pillar-Set-for-C8-LED-Flashlights?search=c8
thanks,This one doesn’t copper as declared but brass
right?
Wieselflinkpro: Alen:C8 copper pill with threads measure like fasttech brass pill are available?
right?
brass looks different: https://www.fasttech.com/p/1208600
I think someone wrote that he has bought it an it was realy copper.
As some of you know, near a year ago Ive started to provide cnc made parts. This improved quality and abilities, but I couldnt provide rare parts anymore so I had to refuse when got pm with custom request.
I dont like to leave somebody dissapointed, I would like to give the last chance so anyone could make any pill Ive ever made.
List, from big to small:
Courui D01
Small Sun ZY-T08
HD-2010
Brynite B158 (2pcs reserved)
P60 single led stock reflector (7/10 pcs reserved, will be machined next week)
Ultrafire or another brand SK68 clone
Surefire type E?I can make any of them last time (MOQ=5pcs, GB open) $25/20/15/10/10/10/10, or
sell any die (tool that I used to make good quality calibrated threads) just for $10.
Whats the price for the Courui D01 Pill? And whats the material?
$25, copper
Hi Kiriba
can you please PM me for 2 (Copper spacer+brass centering ring set for quad mod Convoy M2)
$25, copper
Ok, I let my custom aluminium Pill inside.
